PowderCoating vs. Replacing Parts - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 12-18-2015, 06:04 PM   #11 (permalink)
Brizzman's Avatar
I'm deffinitely interested.
Brizz
05 Speedstar Stage IV
Brizzman is offline   Reply With Quote
Old 12-18-2015, 06:22 PM   #12 (permalink)
dragstar's Avatar
The amount of prep you do depends on the shop you choose and how much you are willing to pay. I had my wheels, handlebars, all brushed aluminum engine covers, foot peg brackets, and maybe a couple other things done at a high volume powder coat facility for like $150 (probably off the books), but I had to do all of the prep work. Then I had all the chrome engine covers done at another shop for $200, but they did media blast the chrome and do all of the prep.
dragstar is offline   Reply With Quote
Old 12-18-2015, 07:29 PM   #13 (permalink)
fruitjacket's Avatar
Thanks Dragstar! Good info to know!
fruitjacket is offline   Reply With Quote
Old 12-18-2015, 10:36 PM   #14 (permalink)
RCOLIGAN2,
I assume to remove the shift rod end clevis, you have to take out the ring clip/circlip.
How the F?
Everytime I use something to get in there it just spins around and there's no way I'm getting two flatheads in there.
Tip?
Originally Posted by rcoligan2 View Post
On the shift peg use a small flat head screwdriver to pry up on the end of the rubber. Then shoot a little WD-40 under it, twist and pull to remove. May need to use the screwdriver to help. Remove pinch bolt, then lever from shaft. Don't P.C. shaft. On the shift rod end. Remove the nut,then the rubber boot and you will see how to remove the clevis. Don't P.C. the "ball" or the removed parts. On the foot peg mount remove the shift lever bracket and foot peg. Don't P.C. the foot peg retaining pin or through hole or any bolts, nuts or threads.
Old 12-18-2015, 11:12 PM   #15 (permalink)
The easiest will be circlip pliers available at auto parts store.
Old 12-19-2015, 07:49 AM   #16 (permalink)
Seems obvious.
Next time I'll think. Lol
Old 12-22-2015, 11:51 PM   #17 (permalink)
dragstar's Avatar
FYI, the place I got all of the cheap powder coating done was called central iowa powder coating in Hubbard iowa. If you are on the south side of the cities it is probably only a two hour drive. It's probably not worth it unless you are doing a ton of parts, but it could be worth the trip.
Old 12-23-2015, 12:01 AM   #18 (permalink)
Didn't work. Broke 2 pairs trying and bent 4 metal picks.
I know the sumbitch will come out, but man is it tough.
I'm leaning towards not doing the part. With all I'm doing, I don't know that I want to fight it that much.
Old 12-23-2015, 04:32 AM   #19 (permalink)
D*mn! It's been a little while since I had my eyes on it. Wouldn't have thought it was that bad.
Old 12-23-2015, 07:01 AM   #20 (permalink)
Truth: I had a Harley Certified Mechanic over at my place the other day. I asked him to bring his ring remover. I let him try it for about 30 minutes.
He couldn't get it.
