help poor throttle response /hesitation - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 06-17-2017, 11:29 PM   #1 (permalink)
Question help poor throttle response /hesitation
hey every one so unfortunately my rear wheel slipped out from under me and i dropped my warrior broken peg and brake lever so i got them replace bike idles fine and if im super easy on the throttle it drives but if i pull the throttle any faster it hesitates and then bam it kicks in . it takes a full second for it to respond also my engine light is on i noticed after picking up my bike when it fell noticed the lag shortly after . any tips thanks in advance.
Tommy750e is offline   Reply With Quote
Old 06-17-2017, 11:46 PM   #2 (permalink)
Desertboy13's Avatar
Wow... Welcome from SoCal ride safe.... Sorry that I'm no help... But one of the guru's will chime in with some help.... Guess have u check the usual stuff connections n so ?
Where in Cali are u from
Sent from my Z831 using Tapatalk
Old 06-18-2017, 01:02 AM   #3 (permalink)
rij1's Avatar
Check what code it's throwing otherwise like I'm at mentioned, connections.
2002 XV1700 Roadstar Warrior
My Mods
Cobra Fi2000 PowrPro with CVT(Non-Black)
Bub Chambermaids
Big City Thunders - Thunder Monster Baffles
Rudy Jeremias
(562)303-6036
Old 06-18-2017, 02:09 AM   #4 (permalink)
Brizzman's Avatar
Welcome to the forum. Post up the specs and modifications you know about your bike. Once you have enough posts (10 I think) you can post pics as well. If you have a Power Commander or other fuel controller, it's possible some connection has come loose.
Brizz
05 Speedstar Stage IV
Brizzman is offline   Reply With Quote
Old 06-18-2017, 07:29 AM   #5 (permalink)
Welcome to the family! Disconnect the battery for ten min. then re connect. Then check what code/s show on the tach. if none check the code history. Also like said check all starter and battery cables for clean and tight connections. what side did it fall on? I fright it could be the throttle grip hanging up.
Old 06-18-2017, 08:40 AM   #6 (permalink)
Shadow Warrior's Avatar
Welcome to the warrior family and the best warrior 4m.
Old 06-18-2017, 01:48 PM   #7 (permalink)
rumblemonkey's Avatar
Welcome and the above comments are on track-if it fell on the right, make sure the throttle is smooth without the bike running. A Vacuum line or cap may have come off also. Check the codes and let us know so you can get back to having a great running bike!
rumblemonkey is offline   Reply With Quote
Old 06-19-2017, 12:53 AM   #8 (permalink)
Awesome help guys!
