I have a 2006 warrior, I am able to get the bike to start (only if I have the clutch lever pulled in) once the bike is running in neutral I go to release the clutch (still in neutral) and the bike stalls out. Same thing if the clutch is in and I drop it into gear it stalls. I have checked and bypassed the kickstand switch but the bike still stalls out if I let go of the clutch. I checked the clutch sensor on the handle bar as well, all sensors seem to be working how they are supposed to be. Any Ideas on what could be going wrong with the bike?
I don't know if there is any history with this problem or if it's a new occurrence.
Enclosing a Hosted Snap-Shot of the Late Relay Unit as a troubleshooting tool for your issue.
Based on your OP it's obvious that the ECU is NOT seeing the Sidestand UP and the reason the engine is cutting out when NOT in Neutral.
It is doing exactly what it is designed to do.
There are only several reasons for this issue. Bad switch, blown diode (D6), poor ground or poor wire connections.
I suspect you're going to need to visually inspect the wiring @ the Relay Unit and perhaps check the referenced D6 diode.
Taking wire Blue/Yellow (-) to chassis ground (Temporarily) will defeat the prestart interlocks and allow you to start the bike so proceed at your own risk!
Thanks I will look further into that. I still don't get why it cuts out if it is still in neutral, This issue just started after the bike sat for 2 weeks
Is this condition correct?
The bike when in neutral (neutral light on) & sidestand up will not start unless the clutch lever is operated. Then when shifted into gear the engine cuts out.
If above condition is correct then there is an issue with the Relay unit diodes or wiring connections at relay.
I just re read your original post. My bad. How tight is your clutch cable? What happens if you give it some throttle while you release the clutch in neutral?
When I first noticed the problem I replaced the clutch cable as the old one was stretched pretty good. I could be revving the **** out of it in neutral the second I get a quarter release on the clutch lever it cuts off
Thank you guys for the ideas on tracking down the issue, I was able to find the route of the problem. It was a short in the wire to the clutch sensor caused by a mouse getting into the headlight and chewing thru a ton of wires. I was surprised it even started. Thanks again
you would be surprised where those little assholes can get into!!! Glad you figured it out, you came to the right place for help.
Related Threads
RS Warrior Forum
1.6M posts
36.1K members
Since 2002
