Correct Drive belt deflection on side-stand - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-02-2019, 09:42 PM   #11 (permalink)
I forgot to add that because my bike's rear is lowered I worry about the change in static position in the arc with respect to belt tension moving throughout the arc. If the swingarm is pointing exactly 90-degrees from the front pulley then the belt is at its tightest in its arc range. Above and below 90 its arc effectively loosens the tension. So as my rear suspension acts it will cause my belt to become tighter at moments and looser at others. I take that into account by targeting 7mm ~ 8mm as my 'on-the-kickstand' number. Its not enough to snap belt off the line at WOT unless I really f-up.
All of those numbers are still between .25 and. 33 inch so I like to use mm and skinny it up. I worry about looseness at the ends of the travel range if I'm for example leaned into a corner and go WOT on exit, which snaps-up any slack. Same for standing start WOT it squats down even lower real quick even with the Eibach 1000. So far so good.
Old 11-03-2019, 03:53 AM   #12 (permalink)
ThingFish's Avatar
is there a way i can tell if my bikes rear has been lowered?
"When life get's you down remember it's only one down and the rest is all up"
ThingFish is offline   Reply With Quote
Old 11-03-2019, 04:02 AM   #13 (permalink)
rij1's Avatar
From this picture of yours it does not look like it is lowered.
2002 XV1700 Roadstar Warrior
My Mods
Cobra Fi2000 PowrPro with CVT(Non-Black)
Speedstar Gen2 Exhaust
Rudy Jeremias
(562)303-6036
