Head Job Info needed - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 06-21-2012, 04:58 PM   #11 (permalink)
Flyingdutchman's Avatar
Originally Posted by Churchkey View Post
You may have a lifter going bad or you may have cams going bad.
After removing the lifters place a straight edge on the base of the lifter & hold it up to a light source. A lifter base is machined convex so that the lifter will rotate as it cycles. You should be able to see a bit of light on one side of the base under the straight edge. If so the cam lobe is good that the particular lifter lived with. It the lifter is flat or is worn concave you also need cams.
Woody,
Thanks for this additional information, I will check this.
As the 'ticking' is not continuous I hope it is not a cam lobe. Having mentioned this though, the lifter rotates so there might be cam as well as this might have a flat spot (if this makes sense)
Dutch
Made in Holland
Transported around The world
Libertad Siempre
NL_NZ_SA_AU
Flyingdutchman is online now   Reply With Quote
  Road Star Warrior Forum : Yamaha Star Warrior Forums > Ride Club > Australia
