Tip for Re-Assembling a Starter's Brushes - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 09-22-2014, 03:15 PM   #11 (permalink)
I decided to put on my creative hat today before tossing the old parts because i don't own office furniture .... so if you ever run into a difficult rebuild per my OP a Dime or Canadian Nickle will work too!
It's not likely you'll ever run into a smaller starter brush set than shown here
***1187***
- Starting System
Old 09-23-2014, 02:17 AM   #12 (permalink)
Awesome! And no tin snips required!
Old 05-23-2017, 05:50 AM   #13 (permalink)
Caledonian Warrior's Avatar
I'm changing the brushes on an 05 starter and can't get the **** brushes to stay while fitting over the commutator.
None of the info above applies for the fitting of the new Warrior starter motor brushes as far as I can see. Totally different set up with the springs, plate screws and access.
Has anyone on the forum ever changed the brushes on a Warrior starter? if so, any advice or pictures out there would be much appreciated?
UPDATE...... done and dusted with some help from Heff..... thank's Heff
I'll post some pics later.
TO SEE OLD PHOTOBUCKET IMAGES WITH FIREFOX..
TO SEE OLD PHOTOBUCKET IMAGES WITH GOOGLE CHROME..
Last edited by Caledonian Warrior; 05-23-2017 at 08:22 AM. Reason: brains were somewhere else late last night...all sorted now.
Caledonian Warrior is offline   Reply With Quote
Old 05-23-2017, 06:58 PM   #14 (permalink)
Glad you got it!
Old 05-24-2017, 01:39 AM   #15 (permalink)
heff's Avatar
Thats alright big fella glad to help on the other side of the world. Its all easy now and you are now the northern expert, lol
Heff
heff is offline   Reply With Quote
Old 10-13-2017, 01:35 PM   #16 (permalink)
milkman672042000's Avatar
Here is what I used recently to hold the brushed back. pieces of 14 gauge copper wire WITH the insulation on them. I tried it with no insulation and they would slip out.
16 gauge probably would of been better but 12 gauge would be to big.
I also found it easiest to take the gear off the end of the shaft. That way I can then set the armature, I think it the right term, in the brushes and then slide the center housing, with magnets, on. Just be careful the magnets will pull that housing down at approximately 9 million MPH. Then just set the top plate on and bolt it together
ID:	190185   Click image for larger version
How to's
milkman672042000 is offline   Reply With Quote
Old 10-13-2017, 05:52 PM   #17 (permalink)
Brizzman's Avatar
This look like a solution that would work for mine. I've got Joey's old starter in there for now and it works, but mine looks better.
Brizz
05 Speedstar Stage IV
Brizzman is offline   Reply With Quote
Old 06-19-2018, 04:36 PM   #18 (permalink)
+++1!
Old 06-19-2018, 09:27 PM   #19 (permalink)
WORYR's Avatar
If I have to do this someday, lots of great info!!! Love to see different ingenuity to get the job done!
WORYR is offline   Reply With Quote
Old 05-21-2019, 11:59 PM   #20 (permalink)
Kruger's Avatar
Does the starter need to be re-lubed with engine oil after disassembly and cleaning?
Don't believe the hype!
Kruger is offline   Reply With Quote
  Road Star Warrior Forum : Yamaha Star Warrior Forums > Warrior Forums > Technical Discussion > Tech Tips
