1 - 9 of 9 Posts
yeah I was just looking at it and was going to ask if it was a good deal and weather anyone knows if it is better to go with wet or dry nitrous
You need some way of adding extra fuel when the nitrous oxide is on to take advantage of the extra oxygen avialable or you will lean out bad and burn a piston.[xx(]
I don't believe it nos installed wrong will put a hole in your
pistons then $250.00 will be$2500.00 good luck.[xx(]
pistons then $250.00 will be$2500.00 good luck.[xx(][8][/emoticons/emotion-6.gif!][V][?]
1 - 9 of 9 Posts
