1 - 19 of 19 Posts
I didn't realize how hard it was to find the 18mm allen wrench for the front axle ..... Wow I looked everywhere even a machine shop supply company .. Nobody had one ...NOBODY !!!! I just happened to mention this to a friend and he said he had one that he "borrowed" from a shop he used to work at .... Thank-god .... I took it home and painted it bright orange so I won't lose it .. I'm thinkin of getting it gold plated .... LOL Good luck if you guys need one ... [/emoticons/emotion-5.gif]
All you need to do is get the closest standard size bolt and 2 standard nuts, lock the 2 nuts together on the bolt and you have yourself a front axle remover tool for a couple of bucks$$....easy enough.
quote:Originally posted by icepick
dam thats not what i need to hear. just ordered turn signal brackets from alanh for the front forks.
What does the front axle have got to do with front turn signal brackets?
The wrong end of a 3/4" cold chisel will work, some spark plug sockets have a 3/4 hex at the top. If Sears is near by, they will have a 3/4" allen wrench. your choice.
Thanks Darkstar .... Wish I knew that 2 days ago .. Very good idea .. Guess I wasen't thinking .. I'm starting to take bike apart to paint and do alot of powercoating ... My sister married a guy who owns a powercoating company .. He said I can do what I want for free .. If I do the work on it .... O BOY !! O BOY !! ... Thanks again for the Idea on the axle ..
Boy you lucky all I get to do is install roofs for my motherinlaw and pick up her trash[/emoticons/emotion-6.gif]quote:Originally posted by 99prf
Exactly what I use.....fits like a glove....
The ratchet end of a 5/8" spark plug socket works like a charm. They have a 3/4" hex on the end so you can use a open end or box wrench.
I picked this axle tool up at my local dealer it fits on a 3/8" ratchet.
Insert Image:
34.44KB
Maybe that's because it is 19mm. [/emoticons/emotion-2.gif]
I was wondering if anyone was going to catch that, I flip the plug socket but have a Snap-on allen socket @ work
1 - 19 of 19 Posts
