I've tried several times to install my clutch cover. It does not want to go on easily. The first time after install I couldn't pull the clutch handle. Took it back off and got it on somewhat easier but now the gear shifter wont move. The clutch seems to be working fine. I am able to remove the shift shaft assembly easily from the case by hand. Is that normal? I have the Push 1 Rod (P/N 4XV-16356-01-00) facing the rear during install. Any suggestions would be greatly appreciated.
vhockin
vhockin
