1 - 10 of 10 Posts
Does anyone know how much time can be knocked off a quarter mile by dropping 2 teeth off the front pully?
Common Shocka, you can do better than that!! lets go, go, go!!! LMAO!!!
Not yet but check on topics for racing warriors or et times and maybe... By the mean how much is your terminal speed at 1/4 mile? That can help you for calculate that same speed before changing teeth off the front pully. I think will do better at 1/8mile. Good Luck!
If it is worthwhile, I would swap out the pully. I can give up some top end speed for bottom end grunt.
I think Baron's has a 33 tooth pully available. I don't know if it fits the warrior or if it is a road star only product. Same thing I think for 31 and 30 tooth pullies.
I installed the Baron 31 tooth pulley. I have'nt had the chance to make it back to the track, will probably go this wensday. By the BUTT DYNO, it has made a difference.
RexWarrior installed the 31 tooth Roadstar pulley so I think you can go with both. The Barons is a little cheaper I think and it fits perfect. The Roadstar pulley is a little bigger in width but it works. Beware of the Nut. The nut that holds the pulley on. That son of a [email protected]#$ is tight. Use an impact if you have one. If not a big cheater bar!
1 - 10 of 10 Posts
