I want a 33 tooth pulley that is already machined down to fit our bikes. New or used, I don't care. I have a 31 tooth that I might be willing to part with as a trade.
The Yamaha pulley you have is made for the '99-03' Road* w/ 1-1/2" wide belt so it will workfine.Alberta Warrior said:It's the Yamaha Roadstar 7075 aircraft grade aluminuim one. From what I read it's far superior to the aluminum that Baron's were using for theirs (caused everyone all the grief of wearing out). Not sure of the width because it's still on the bike, but it bolted right up with out any clearance issues. I can pull the cover off and get a measurement if you want but I'm sure itis the same as stock.
thanks alanAlanH said:The Yamaha pulley you have is made for the '99-03' Road* w/ 1-1/2" wide belt so it will workfine.Alberta Warrior said:It's the Yamaha Roadstar 7075 aircraft grade aluminuim one. From what I read it's far superior to the aluminum that Baron's were using for theirs (caused everyone all the grief of wearing out). Not sure of the width because it's still on the bike, but it bolted right up with out any clearance issues. I can pull the cover off and get a measurement if you want but I'm sure itis the same as stock.
