Elea247,
If the dealer downloaded a map for your PCIII then it should be good to go. There's no need or way to advance the timing...Being you said the map is supposedly a custom map, I'll assume that the dealer dyno'ed the bike and created a map for your set-up. If they didn't then they probably just downloaded a map from Powercommander.com that was close to your set-up.
What kind of pipes did you install? Samson, Vance & Hines, Cobra, Hard Chrome, others?
Any other mods?
Go to
www.powercommander.com and check out the available maps that are there for the RoadStar Warrior. You can download them all or pick the one that is closest to your set-up. Try the map closest to your set-up and if necessary make slight adjustments manually on your PCIII, until you get your bike to run like you want.
I highly recommend that you do the "Perfect Install" on your PCIII, if it hasn't be done yet. Well worth it!![^]
There are also some good maps here...See if there isn't one that is close to your set-up. Or if you like tell us what your set-up is and we can probably find a good map for you to try. Unless you have your bike dyno'ed and a true custom map done...You'll have to settle for something that is close and make whatever adjustments necessary to get your bike to run the way you want.
Oh...And you can't compare a "super bike" to a "performance cruiser"...The Warrior is a different kind of beast...But be warned it'll surprise you![/emoticons/emotion-5.gif]
Mark aka Mad Man
