1 - 3 of 3 Posts
Hello All,
I have a 99 Silverado with not a key one, ignition was mangled in the garage. I'll drill out the fuel cap NP. My issue is can I bypass the mangled switch in the harness to start her with the HB switch?? It's a 6 pin plug and I don't want to F..K IT UP. I appreciate any help you may offer me.
'05 Midnight
Sorry, buddy, but you're in the wrong place. This forum is dedicated to the Warrior version of the Road Star. Please checkout Forums - The Roadstar Clinic for your type bike to get proper support for your issue.
Best of luck to you!
The 1999 RS Silverado is the 1600 carbureted motor, far fewer sensors etc. There is a shop manual over on roadstarclinic.com (linked by Random) plus they know your bike better. Look at the function of each wire on the wiring diagram. It's likely a short process-of-elimination. Remember you might need to only start it in neutral for safety. The key switch has a security screw needing to be drilled-out, buy a replacement from Yamaha before starting the work.
1 - 3 of 3 Posts
