1 - 1 of 1 Posts
Hi,
I was trying to remove today the bolts on the motor mount, in order to grind it and paint it (ferraci dry break and left side cleanup mod). I fired my compressor and the 450lb 1/2" impact wrench... the Allen bolts did not move at all. So I decided to grab my ratchet and a rubber hammer to unlock those stubborn bolts. While applying a balanced pressure and hammering gradually, the titanium Allen key snapped like a thin piece of wood. I hope no locktite was used on those bolts, the previous owner made few moves like that on some important bolts...
So far, the solution is to heat a little the bolt with a low temperature torch and try again to unscrew it... Do you recommend another approach? Also, do you know a good Allen key set that I can use with my compressor and will not snap like a pair of matches when used on tough bolts?
Thanks guys.
1 - 1 of 1 Posts
