1 - 20 of 76 Posts
Just did the oil change this morning and thought I'd share....First thing I did was ride the bike for about 15 mins around the block to loosen up the oil.
1. This is where the oil goes in..
2. I switched to Mobil 1 from Amsoil. I didnt feel like looking for the amsoil secret society so I just went to walmart. Plus I heard its just as good.
3. Over to the front left side of the bike, you will see the 1st drain plug (I have the wrench on it).
It is 17mm, if its not, do not remove it.
4. While your there, remove the filter as well;
5. Now the rear drain plug....Again it is 17mm!
6. I measured how much came out by putting the drained oil into an empty 5 qt container. As you can see 4.5 qt came out, and thats what I put back in.
******After filling her with 2.5 qts, start her up for about 10 secs and fill in the rest. And make sure you tighten everything back******
Great idea putting this on here again. When i done my first oil change a while back i had so much trouble finding the rear plug. I actually found most of the written info but the threads were so old the pics didnt work anymore. I accidentally removed a plug from transfer case before i figured it out.
I know this is dorky, but a few years ago I changed the oil and forgot to put ONLY 3.5 qts in then start it, rev it a few times, shut it off, then continue filling it up. Instead, I just started pouring and pouring right down the funnel until I had oil coming out the top of the oil tank and running all over the bike and all over the floor:mad::mad::mad:.
So, dorky or not I didn't want to do that again and I was always having to look up to see how much oil it takes when i was due for an oil change so this is what I came up with.
I used an old laundry detergent container and cut it down so it would fit under the bike and wrote directions for my short term memory.:rolleyes:
On the other side I made note of how much oil the tank and engine hold.
Pretty pathetic, huh?:eek: Oh well, it works!!!
NOT pathetic. I think its a good idea, i like to see people who are picky maintainers. If you were ever to sell (to buy another warrior of course) you could show somebody this and they would say " wow this guy takes good care of his stuff ". BTW i overfilled first time also, WHAT A MESS!!
When I first got my Warrior I wasn't used to having a bike with a dry sump oiling system and over filled it too. As a result of that I now have a turkey baster in my garage as part of my tool collection. :)
That's so true! Last year I was changing the oil in the garage. It was the end of the day after work, I was a bit tired so I removed the transfer case plug.
Pro: new transmission fluid
Con: had to spend extra time and money.
So make sure it is 17mm
I like to see people who are picky maintainers. If you were ever to sell (to buy another warrior of course) you could show somebody this and they would say " wow this guy takes good care of his stuff ".....
Right! Little did they know he took it to the strip and dragged it all day long after the oil change:D....LOL.........................................j/k.....thanks for the tutorial, I like it.
A well maintained bike does not always necessarily mean it was ridden sensibly though. I take really good care of my Warrior, but I ride it like I stole it. The same goes for my S2000 and ZX6R. Having said that a well maintained machine with good records is always a safer purchase over one without one, regardless of how it was ridden.
Now everybody go to your garage, put he bike against the wall and do some rev-jumping burn outs in 3rd gear:D
Forgive my newbie-ness, but do you have to ride it prior to changing, or can you just let it get to operating temp and change then? Got a REAL low front tire so that's why I'm asking. Just gonna pull the front wheel off and go to local gas station to put air in it.
you can just warm it up if you want. or go fill the front tire and then change the oil after a short ride. but what you REALLY should do is go buy a cheap air tank. it'll come in handy on occasion
1 - 20 of 76 Posts
