1 - 2 of 2 Posts
Hi there! I was going to buy a Barnett clutch kit but it says it fits 03 and up? I have looked and I dont see one for an 02? Am i missing something? Will it fit the 02?
Yes. All the clutches are identical.
Options:
You can buy red springs (very very heavy) or buy green springs (very heavy); it comes with gold springs (heavy).
You can do the clutch fiber disc mod in two variations.
You can order a stronger Barnett clutch cable matching stock, with a Teflon, Nylon, or HDPE inner liner.
My set-up:
Barnett SR2/511-90-10002 clutch spring assembly (gold springs).
Yamaha OEM fiber and steel clutch discs. Coated stainless braid with Teflon lined cable. Zero maintenance other than ball-end WD40 at time of motor oil changes. And few-and-far-between adjustments over time of course.
1 - 2 of 2 Posts
