1 - 4 of 4 Posts
248513
Hey guys,
I can't figure out if I'm lowering the bike correctly using barons lowering links. I released the jam nuts shown on the first picture by blue circle, I then adjusted the hex adjuster shown by red arrows. Then I noticed that the nuts on the other side of the hex adjuster were loose, shown in the second picture. Should that be like that? Should I tighten thise nuts too? The instructions dont talk about that so I'm worried. Can anyone comment on this? Also does that look like too much of a thread exposure?
Thank you
Perfectly normal adjustment. If you loosen the lock nuts on the front end and screw the hex adjuster in (increasing the overall length lowers the bike; shortening it will raise the bike height) the lock nuts on the other end will be loose. Once you adjust the links equally to get the height you want, just tighten up the lock nuts on both ends.
1 - 4 of 4 Posts
