1 - 20 of 77 Posts
Sunday 9-19 All Bike meet @ Thompson Drag Raceway Thompson, Ohio
Temp 69. 4 mph tail wind. PERFECT DAY
Light .497 (red light) .500 perfect (sucks out in 1st round)
60' 1.701
330' 4.689
1/8 7.317
mph 92.01
1000' 9.699
1/4 11.719
mph 113.79
Mapped for all the work: V&H Bigshots no baffs, BAK Home made, HC Pistons, S* Cams, Valves and pushrods,Dyna coils and wires. Next on the list will be a 31 front pulley
How much does the rider weigh? That has ALOT to do on a bike. He must be one he11 of a rider. That is a good 60' time. The 60' makes all the difference in a drag race.
That's a full second better than mine, but I have a stock motor with intake mods and PCIII only. My 60ft. was like 1.801 or something. I have only ran it three times and best was my third. Times in my sig.
Hey, Terry, Craig, we need to get together and run em at the strip some time!
Mine bike dyno before BAK 92HP and 114tq and i run 12.4 and 107mph 230 pounds rider.
By the way Tarry what was your time?
quote:Originally posted by amospro
Pretty **** good numbers. I have the same set up and my best is 12.4
I wouldnt have told that[/emoticons/emotion-2.gif]
I didn't get very good #'s for my stock setup, according to the factory, and I worked at it.
But the factory probably had a 90lb. ninja diong the tests and I weigh 200+.
235 lbs/ 11.764 @ 112.51 mph...I'll take a picture of it and get it up soon. Other members were there @ Thompson 8/22/04. This was first time racing ever...107 hp and 120 ft/tq
I'd bet Jay(ProStreetWarrior) would run low 11's easy on my bike, and if I got the quickshift, a slick and bored throttle bodies we'd see 10's.
Red Horse and I made it to LACR (Palmdale, CA) to play and have fun...my first time draggin my bike legally. I wasn't too happy with my driving, and he wasn't too pleased with his fuel map, but we had fun..BTW-the harley that was competing with us broke (leaking oil) before the elimination started. I'm 169 and he's 226. The first run was against a hayabusa...
Diver
Insert Image:
81.09KB
The 1/8th mile times look like you might both have had some wheel-spin, (even the Busa had some unusual numbers) but it looks like y'all had plenty of chances for runs... I like that your track opens so early, too.
no, he ran a 12.6--and it was the first run of the day...still getting a feel for the track and the bike...I ran 14 on that one..neither of us did well....but all I saw were taillights. was excited enough that I had bad rt, and screwed up every shift...but at the end of the day, I made it into 12s and went away happy.
Diver
We ran 7.36 in 1/8 this pass friday night with hc pistons,bak,propipe,
orient express nitrous setup.
nos pressure to low no bottle warmers looking for 6.90s this weekend
with correct pressure,still have alot to learn about running nos.
I took mine to the track tonight for the first time. I was going to wait until I got the new tire because the one on it has a flat spot all the way around in the middle, but I gave in to peer pressure. The first run I reved it up a bit to high and pulled a pretty good wheelie. The second run I let it go from somewhere between 1500 and 2000rpm I think. The bike has jug huggers and a PR air kit.
1st run:
60' 1.924
330 5.441
1/8 8.402
mph 82.66
1000 10.995
1/4 13.206
mph 100.63
2nd run:
60' 1.867
330 5.221
1/8 8.078
mph 86.01
1/4 12.797
mph 102.38
I don't know if that is good or bad for the bike but it was the first and second time I have ever ran it at the track and it went faster than anything else I have ever owned. Was a **** of a lot of fun too.
I also weighed the bike. It went 825-830 with me on it and 630 with out me. The scale is made for cars and goes in 5# incraments so I don't know how accurate it is for bikes but I bet it is pretty close.
this is my first time ever running a dragrace...
here is the numbers
0,400tree
0,00dial-in
0,597reaction
1,93660foot
141,34km/h
7,948 201m
this is 1/8 mile race
Went out yesterday for the first time at the local track Firebird, ID. I weight in at 201, Big shots, BAK, Lowered, 1000 lbs spring, 240 tire, 38 PSI. I was going to see what I can do before I start adding Mods PCIII, HC pistons, etc…
R/T---.268
60'---1.880
330---5.217
1/8---8.090
MPH---85.33
1000--10.622
1/4---12.791
MPH---103.55
Chad, did you mean your first time or just the first time at that particular track?... 'cause those are some really good times for a first run with the stock motor and that tire. You're reaction time and 60' will only get better. **** good work, Boss.
(Love the wheels you got, by the way. Makes that Indigo really look evil.)
First time at the track I ran 5 times that night all in 12.9 thru 12.791 last run I figured to take off at the third yellow helped that run I was sitting R/T at .55 waiting for green to release. It will get better. Thanks!
Just Love This Bike!
Insert Image:
38.72KB
1 - 20 of 77 Posts
