1 - 19 of 19 Posts
Hi all, I'm in the need of a new battery and was wondering what brand/type of battery people prefer. Please post comments about what u like and what to stay away from.... Thanks!
Ross
Imo- lithium iron battery is the way to go. They do have their pitfalls so research before order a particular brand
Vendor
Scorpion makes a battery for the warrior. Around 130 bucks its lithium iron snd smaller than a stock battery...I will be ordering one next week.
I just bought a Bikemaster AGM battery. works great. Cant trickle it with the chargers we are used to, but doesnt need it for weekly/monthly down time. You would need a full size charger like diehard, that trickles AGM batterys. You would only need to trickle it for winter storage or lengthy storage longer than 4 months they state. weighs about the same as lead acid, $90 shipped.
I just bought the same battery for mine, 348 CCA's, as well as a Shorai for the MT-01, 270 CCA's. Batterystuff.com
So far, so good....both bikes turn over like crazy, even with sub zero temps and cold 20w50 oil in both. I ended up using some left over foam from the Shorai to boost up the Scorpion, as it's about 0.5" shorter than the Shorai.
2006 Warrior
Scorpion AGM is the best bang for the buck! I've put them in every bike I own . They have never let me down and have double the life of the typical yuasa batteries
I put a Shorai in my Warrior just this week. I've had one in my CRF450X for a few years and I love it. Holds a charge forever and will spin the motor noticeably faster at crank. Plus the weight and space savings is great, I can stick a small pelican or otter box in the leftover space for extra sealed storage.
check this thread on scorpion that is curently posted
http://www.rswarrior.com/forums/20-product-reviews/196329-scorpion-battery-batterystuff-com.html
I believe if you go with a lithium battery you have to get a trickle charger specific to lithium batteries as the usual trickle chargers will not work you would need to compare the expected life of a lithium compared to the life of a regular battery like a scorpion and then see if it is cost effective considering the cost of a charger as well
Now that's it been a couple years....Have you had any problems with the Scorpion, or Shorai for that matter, battery holding a charge or having hard starts?
Shorai in mine and even with HC pistons it still cranks right over. I also have one in my HD Road King. Also Shorai warranties their battery for 5 years no pro rate. Found the best price at PDI Racing.
Shoari battery. Mine's at least 3 yrs old my bike sat outside all winter long 4 1/2 months no charger left connected. I only started maybe twice and the battery still fires up.
Shorai it is then. Is it worth buying the Shorai charger for it as a just-in-case? I have a battery charger and a battery tender 800 now.
It's a expensive battery so I bought the charger to go with it. You need a charger that's designed to charge these types of batteries. Plan on spending around $170 for the battery and another $80 on the charger. The shoari is a smaller battery as well which I found to be very beneficial, I put my pc3 in the battery box on top of it really cleaned things up under the seat.
It seems that Shorai is the preferred battery, but some of us have purchased the Battery Tender BTL14A240C and have had good success including myself.
https://www.amazon.com/BTL14A240C-L...TF8&qid=1523571039&sr=8-1&keywords=BTL14A240C
I recently bought and installed this same battery (BTL14A240C). Now with hi-comp pistons it struggles a bit, at least on mine. If you pull up to some place and hit your kill switch thinking you're done and then have to restart your bike, you can most likely count on having to totally shut off your bike (key) and start again so the headlight doesn't come on. I was going to get my bike inspected and did the same... wouldn't start until I killed the headlight. A little embarrassing. I was wondering if the BTL24A360C might be a better choice for hi-comp. I don't know enough about the battery tender ones yet. My previous was the shorai and I had no issues with it cranking over my motor.
1 - 19 of 19 Posts
