Thanks for the input guys, "mush-aprish" as they say around here.
Looks like I'll go with what JamesD has, swapping out the two half frictions, and replace the third halffriction with stock. That is, if I understand what Alan is saying??
Alan, I bet you're right about the hub and basket, but I am a cheap sob and I'm hoping for the best. I'll get a mike on those drive plates but they don't seem to wear much. Claudia's V-star had 89k on it and the drive plates looked like new??
[*]Flatness of the steel plates is just as critical. Be sure to read the
Clutch plate replacement pointers - Recommended Reading that i provided earlier. Has some excellent pointers regarding the installation and directionof the sheared/stamped parts being installed in the same direction![/list]
And yes, I have a spanking new CPS kit on the benchwaiting for a good reason to crack that case for more than a year now.
[*]You'll probably need a cross point impact screw driver to remove the 2-CPS screws.[/list]
The "pull rod brg"?? Same as clutch release or throw out bearing??
[*]Yes[/list]
I think that one goes with the Barnett plate
[*]It's thebrg that fits within the c'bore of the Barnett plate[/list]
...should outlast the bike.
[*]I don't know about that
but you're in the Pilot's seat on this one![/list]
I thought about sending the Barnett plate in for replacement, I'm sure they will if I ask. I don't want to take the down time.
[*]I had mine back in 3 or 4 days at no charge. They are located in Venturaas you know[/list]
Maybe next time I need frictions at 200k.
You know what... I didn't replace the bolts last time.
Don't suppose you remember what size those are do ya??
[*]Almost... Hex Head machine boltsM6 x 1.0 pitch- stock screws are 25mm long
[*]Barnett provided 6-new bolts with the SR-2 kit that were slightly longer (30-35mm)and also 6-heavy washers
[*]Suggest you call Barnett to confirm properlength[/list][/list][/list]
Arizona, I don't have a lot of good things to say about Barnett's line of cables. Near as I can remember... I've had three of them. Motion Pro, and Barron's too. All broke on me and left me stranded. Right now my bike has an old ugly black fat plastic YAMAHA cable on it that has lasted twice as long as the best Barnett can make.
[*]The reason it has lasted so long is because it has a
straight end at the clutch perch and not a
45 deg
just like my customBarnett cable
[*]Ken, i suspect your extremely
wide burly bars and possible constraints of the custom fairing with the angled cable end was causing a premature wear to the stranded cable in the bend .... but i've been wrong before
[/list][/list]
I don't have the number but it fits 99 and up 1600 RoadStar, !SEVEN! dollars on eBay! It's a lil bit too short.
