1 - 13 of 13 Posts
Any 2-1 system will be better for performance than a 2-2 system. the Speed* or Propipe will probobly yield the best numbers. But IMHO theres no substitute for custom
Insert Image:
As stated above, any 2 into 1 will out perform a 2 into 2 pipe.. And yes custom is always better..
Check out my pipes.
Nice Burn-Out Smile - Bucky.
Propipe, Cobra's 2-1, PCS Monster Pipe, Muzzzy's 2-1, Speed*, Forcewinder's Streetfighter are all 2-1 pipes that yield good power.
All depends on what sort of power you're looking for:} A wide spread or good peak numbers. They vary widely so check out the dyno runs of each of the ones you are looking for. The Star 2-1-2 pipe for example, has great low end, is tough to scrape in turns but my Rineharts have slightly more top end. A search will pull up many dyno runs:}
1 - 13 of 13 Posts
