1 - 11 of 11 Posts
So I was going down the HW tonight and I hit a good bump and my bike seemed to cut out like fuel loss and seemed to stay that way until I shift into 4th then back into 5th and it's fine until I hit another big bump again any help with what this could be?
Sounds like loose connection.
I doubt that the tune is the issue. I have a PC3 map in my PCV and it works great.
Most likely it is the LAS. That was the problem on mine when it had similar issues. Mine got worse very quickly and wouldn't stay running even for short rides. Replacing the LAS fixed it.
When you load a PCiii map file into the PCV software i think it is migrated into the PCV software and converted into a PCV map file. When it does that, does the software overwrite/delete the PCiii file, or do you automatically end-up with the new PCV file plus retain the PCiii file? I'm wondering if you need to make copy of and save original PCiii files in a safe location. Thanks.
1 - 11 of 11 Posts
