1 - 5 of 5 Posts
I need some shopping guidance. I broke the peg off my brake lever when I dumped it at the dragon back in sept. Since I have to replace the brake lever, figured Id do the shift lever as well. The only levers that I can find are at msss.com that are in the yamaha catolog. Im not thrilled about the design. Is there anywhere else I can find the levers at?
I made my own pegs for my stock levers. You can drill out your other peg to remove it and buy or make your own pegs. look on some harley parts sites. They have several different styles to choose from. I used a 1 inch solid stock aluminum, and machined 6 grooves into a piece about 2 3/4 long or as long as the stock peg was. drill and taped a 6mm hole in one end, put some 3/4 O rings in the slots. I tappered the outside edge of the peg just to give it a nicer look. I have a picture in my gallery, but you will have to magnify it larger to see it. Hope this gives you some idea's.
1 - 5 of 5 Posts
