1 - 9 of 9 Posts
I broke my key in ignition I took ignition out got it where I can turn with pliers ad key still broken in it I road to store down road from my house and the bike just died can the Start button won't even dim the lights or anythibg when I push it. I have two kick stand up, in neutral, clutch in and everything. I've had this bike for couple years and runs great I don't know what to do. All the fuses are good and with ohm meter I'm getting power everywhere. 2004 Yamaha road star warrior midnight edition Xv1700pc
Share some photos of what you're working with. Is it possible to remove the key?
The when turning the bike on, the headlight is off until it starts. I'd start with a power cycle to ensure the bike is in the proper state for starting as it needs every CCA (cold cranking amp) it can get to turn the engine over.
Discussion Starter · #3 ·
What do you mean power cycle
The Warrior stock keyed ignition is fitted with a Double Pole Single Throw switch that has 2-normally open contacts.
One high amp capacity switched contact handles the positive 12vdc to several circuit fuses and the other low amp capacity switched contact handles the negative polarity ground loop logic circuit for the pre-start interlocks via the Relay Unit & ECU.
I'm assuming you haven't shorted the +12vdc (Red or Brown/Blue) to the negative polarity ground loop circuit wires (Blue/Yellow or Blue/Black) at the switch!
  • Is the Tach displaying a diagnostic Code 19 when Key-ON?
  • Does the Tach & Speedo POST (Sweep) during Key-ON?
  • Does the Fuel Pump operate momentarily during Key-ON?
It's possible the broken key is preventing the ignition switch negative polarity ground loop contact closing completely which would result in the Starter PB not to operate.
Locksmiths use mini tweezers, and mini picks or a micro flat blade screwdriver made for the tiny screws on glasses. They slip it down into the key slot and they catch a tooth to raise the remnant enough to grab with tweezers (or small needle nose pliers) to extract it.
Because you have mechanically turned it to some extent, you'll need to mechanically turn it back to its off position in order to withdraw the key remnant. Its not hard to do but its still a pita.
Then, assuming you have a spare key, you'll hopefully be good to go. If the bike still starts right now then you will be.
It sounds like you might need replacement security bolts, if yes then buy the stock Yamaha ones shown in dealer parts views online (notice the thread with the many links, below, click on any model year of a Warrior).
Adding: in case you (or those who follow in the future) do not have a spare key, the seat and fuel cap lock cylinders only use a couple key teeth so cannot be used to make a working ignition key. Warrior key blanks are available online these days. I'll find the post with the key ID for you. A locksmith can make-up a key even with the ignition installed but get 3 or 4 blanks because it's a hit and miss job. Of course if your cylinder is off the bike then you can take it to them.
The OEM key blank is Yamaha part number 5PX-82511-09-00 however these days the blanks are easily available online as plain metal key, metal key with plastic head, and even with the Warrior or the Star logo head. Prices are stoooopid, so shop and find affordable blanks.
Thrre is a 2021 motorcycle key-blanks catalog as a pdf attached here: (other info helpful but old)
Look on the PDF's Page 41 for Warrior blank which is the Road Star Warrior blank all metal key. It's their part number X248 - YM63. Take these blanks to your locksmith.
BEWARE these kinds of catalogs also include the ATV Warrior 350 so be careful when browsing.
I copied the following from partzilla. Now the Warrior logo key blank part number from the factory comes only with the Star logo and it fits many other bikes. Crazy prices. But can use the model fitment info to fuel your internet search criteria.
This Yamaha 5PX-82511-09-00 BLANK KEY | AP fits the following models and components:
Yamaha Motorcycle 2007 ROYAL STAR MIDNIGHT VENTURE CA - XVZ13TFMWC Electrical - 1
Yamaha Motorcycle 2010 ROYAL STAR VENTURE S - XVZ13TFSZ Electrical - 1
Yamaha Motorcycle 2010 ROYAL STAR VENTURE S - XVZ13TFSZC Electrical - 1
Yamaha Motorcycle 2014 VMAX - VMX17EGY Electrical - 1
Yamaha Motorcycle 2014 VMAX - VMX17ECGY Electrical - 1
Yamaha Motorcycle 2010 VMAX - VMX17ZCR Electrical - 1
Yamaha Motorcycle 2012 VMAX - VMX17BCB Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR TOUR DELUXE - XVZ13CTV Electrical - 1
Yamaha Motorcycle 2005 ROYAL STAR VENTURE - XVZ13TFT Electrical - 1
Yamaha Motorcycle 2013 VMAX - VMX17D Electrical - 1
Yamaha Motorcycle 2015 VMAX - VMX17FCR Electrical - 1
Yamaha Motorcycle 2010 VMAX - VMX17ZR Electrical - 1
Yamaha Motorcycle 2007 ROYAL STAR MIDNIGHT TOUR DELUXE CA - XVZ13CTMWC Electrical - 1
Yamaha Motorcycle 2007 ROYAL STAR MIDNIGHT TOUR DELUXE - XVZ13CTMW Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR TOUR DELUXE S - XVZ13CTSXC Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR TOUR DELUXE S - XVZ13CTSX Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR MIDNIGHT VENTURE CA - XVZ13TFMVC Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMV Electrical - 1
Yamaha Motorcycle 2007 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMW Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR MIDNIGHT TOUR DELUXE CA - XVZ13CTMVC Electrical - 1
Yamaha Motorcycle 2005 ROYAL STAR VENTURE - XVZ13TFTC Electrical - 1
Yamaha Motorcycle 2005 ROYAL STAR TOUR DELUXE - XVZ13CTT Electrical - 1
Yamaha Motorcycle 2005 ROYAL STAR TOUR DELUXE - XVZ13CTTC Electrical - 1
Yamaha Motorcycle 2005 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMTC Electrical - 1
Yamaha Motorcycle 2005 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMT Electrical - 1
Yamaha Motorcycle 2013 ROYAL STAR VENTURE S - XVZ13TFSDC Electrical - 1
Yamaha Motorcycle 2012 VMAX - VMX17BB Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR VENTURE - XVZ13TFYR Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR VENTURE - XVZ13TFYCR Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR VENTURE S - XVZ13TFSYC Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR TOUR DELUXE - XVZ13CTYR Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR TOUR DELUXE - XVZ13CTYCR Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR TOUR DELUXE CA - XVZ13CTVC Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR VENTURE - XVZ13TFV Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR VENTURE CA - XVZ13TFVC Electrical - 1
Yamaha Motorcycle 2007 ROYAL STAR TOUR DELUXE - XVZ13CTW Electrical - 1
Yamaha Motorcycle 2016 VMAX - VMX17GL Electrical - 1
Yamaha Motorcycle 2012 ROYAL STAR VENTURE S - XVZ13TFSBC Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR VENTURE - XVZ13TFXR Electrical - 1
Yamaha Motorcycle 2011 VMAX - VMX17AG Electrical - 1
Yamaha Motorcycle 2011 ROYAL STAR VENTURE S - XVZ13TFSAC Electrical - 1
Yamaha Motorcycle 2015 VMAX - VMX17FR Electrical - 1
Yamaha Motorcycle 2016 VMAX - VMX17GCL Electrical - 1
Yamaha Motorcycle 2011 VMAX - VMX17ACG Electrical - 1
Yamaha Motorcycle 2011 ROYAL STAR VENTURE S - XVZ13TFSA Electrical - 1
Yamaha Motorcycle 2013 VMAX - VMX17DC Electrical - 1
Yamaha Motorcycle 2006 ROYAL STAR MIDNIGHT TOUR DELUXE - XVZ13CTMV Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR VENTURE S - XVZ13TFSY Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR TOUR DELUXE S - XVZ13CTSYC Electrical - 1
Yamaha Motorcycle 2009 ROYAL STAR TOUR DELUXE S - XVZ13CTSY Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR TOUR DELUXE - XVZ13CTXCL Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR TOUR DELUXE - XVZ13CTXL Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR VENTURE S - XVZ13TFSX Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR VENTURE S CA - XVZ13TFSXC Electrical - 1
Yamaha Motorcycle 2008 ROYAL STAR VENTURE - XVZ13TFXCR Electrical - 1
Yamaha Motorcycle 2007 ROYAL STAR TOUR DELUXE CA - XVZ13CTWC Electrical - 1
Yamaha Motorcycle 2007 ROYAL STAR VENTURE CA - XVZ13TFWC Electrical - 1
Yamaha Motorcycle 2007 ROYAL STAR VENTURE - XVZ13TFW Electrical - 1
Yamaha Motorcycle 2012 ROYAL STAR VENTURE S - XVZ13TFSBB Electrical - 1
Yamaha Motorcycle 2013 ROYAL STAR VENTURE S - XVZ13TFSD Electrical - 1
Yamaha Motorcycle 2009 V MAX - VMX17YCB Electrical - 1
Yamaha Motorcycle 2009 V MAX - VMX17YB Electrical - 1
Yamaha Motorcycle 2016 RAIDER - XV19CGR Electrical - 2
Yamaha Motorcycle 2008 STRATOLINER MIDNIGHT - XV19CTMX Electrical - 2
Yamaha Motorcycle 2008 ROADLINER MIDNIGHT - XV19MX Electrical - 2
Yamaha Motorcycle 2008 ROADLINER S - XV19SXR Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR SILVERADO S - XV17ATSXS Electrical - 2
Yamaha Motorcycle 2014 ROADLINER S - XV19SEL Electrical - 2
Yamaha Motorcycle 2014 STRATOLINE S - XV19CTSES Electrical - 2
Yamaha Motorcycle 2010 ROADLINER S - XV19SZCL Electrical - 2
Yamaha Motorcycle 2010 ROAD STAR SILVERADO - XV17ATZW Electrical - 2
Yamaha Motorcycle 2010 ROAD STAR S - XV17ASZCB Electrical - 2
Yamaha Motorcycle 2010 ROAD STAR SILVERADO S - XV17ATSZCR Electrical - 2
Yamaha Motorcycle 2009 RAIDER - XV19CYS Electrical - 2
Yamaha Motorcycle 2009 RAIDER - XV19CYCS Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR - XV17AWYCR Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR WARRIOR - XV17PCYS Electrical - 2
Yamaha Motorcycle 2009 ROADLINER S - XV19SYCG Electrical - 2
Yamaha Motorcycle 2013 ROAD STAR SILVERADO S - XV17ATSDL Electrical - 2
Yamaha Motorcycle 2013 RAIDER SCL - XV19SCLD Electrical - 2
Yamaha Motorcycle 2009 STRATOLINER S - XV19CTSYCR Electrical - 2
Yamaha Motorcycle 2009 STRATOLINER S - XV19CTSYCL Electrical - 2
Yamaha Motorcycle 2007 ROADLINER MIDNIGHT CA - XV19MWC Electrical - 2
Yamaha Motorcycle 2007 ROADLINER S - XV19SW Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR MIDNIGHT WARRIOR CA - XV17PCMWC Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR WARRIOR CA WITH FLAMES - XV17PCWC-F Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR SILVERADO - XV17ATW Electrical - 2
Yamaha Motorcycle 2017 RAIDER - XV19CHCB Electrical - 2
Yamaha Motorcycle 2009 RAIDER - XV19CYCB Electrical - 2
Yamaha Motorcycle 2012 STRATOLINER DELUXE - XV19CTFBS Electrical - 2
Yamaha Motorcycle 2012 ROAD STAR SILVERADO S - XV17ATSBW Electrical - 2
Yamaha Motorcycle 2012 RAIDER SCL - XV19CBCO Electrical - 2
Yamaha Motorcycle 2011 RAIDER S - XV19CSAB Electrical - 2
Yamaha Motorcycle 2011 ROAD STAR S - XV17ASACB Electrical - 2
Yamaha Motorcycle 2011 ROAD STAR SILVERADO S - XV17ATSACR Electrical - 2
Yamaha Motorcycle 2014 ROAD STAR S - XV17ASECP Electrical - 2
Yamaha Motorcycle 2015 RAIDER BULLET COWL - XV19CFB Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT WARRIOR (Onyx) (CA Ed.) - XV17PCTC Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT WARRIOR - XV17PCTCB Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT - XV17AMTC Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR (spoke wheels) Two-Tone - XV17ATC Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR WARRIOR w-flames - XV17PCTC-F Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR MIDNIGHT CA - XV17AMVC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR MIDNIGHT SILVERADO CA - XV17ATMVC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR MIDNIGHT WARRIOR - XV17PCMV Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR SPOKE CA - XV17AVC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR WARRIOR w-flames - XV17PCV-F Electrical - 2
Yamaha Motorcycle 2006 STRATOLINER CA - XV19CTVC Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR MIDNIGHT SILVERADO - XV17ATMS Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR SILVERADO - XV17ATS Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR MIDNIGHT - XV17AMSC Electrical - 2
Yamaha Motorcycle 2014 ROADLINER S - XV19SECL Electrical - 2
Yamaha Motorcycle 2014 ROAD STAR SILVERADO S - XV17ATSECG Electrical - 2
Yamaha Motorcycle 2014 STRATOLINE S - XV19CTSECS Electrical - 2
Yamaha Motorcycle 2014 ROAD STAR S - XV17ASEP Electrical - 2
Yamaha Motorcycle 2012 ROADLINER S - XV19SBG Electrical - 2
Yamaha Motorcycle 2012 STRATOLINER S - XV19CTSBCB Electrical - 2
Yamaha Motorcycle 2012 STRATOLINER S - XV19CTSBB Electrical - 2
Yamaha Motorcycle 2016 RAIDER - XV19CGCR Electrical - 2
Yamaha Motorcycle 2010 ROAD STAR SILVERADO S - XV17ATSZR Electrical - 2
Yamaha Motorcycle 2010 STRATOLINER S - XV19CTSZR Electrical - 2
Yamaha Motorcycle 2010 STRATOLINER DELUXE - XV19CTSZB Electrical - 2
Yamaha Motorcycle 2010 STRATOLINER S - XV19CTSZCR Electrical - 2
Yamaha Motorcycle 2011 STRATOLINER DELUXE - XV19CTFACB Electrical - 2
Yamaha Motorcycle 2011 ROAD STAR SILVERADO S - XV17ATSAR Electrical - 2
Yamaha Motorcycle 2013 ROADLINER S - XV19SDCB Electrical - 2
Yamaha Motorcycle 2009 RAIDER S - XV19CSYCB Electrical - 2
Yamaha Motorcycle 2009 RAIDER S - XV19CSYB Electrical - 2
Yamaha Motorcycle 2009 RAIDER - XV19CYB Electrical - 2
Yamaha Motorcycle 2009 RAIDER S - XV19CSYR Electrical - 2
Yamaha Motorcycle 2009 RAIDER S - XV19CSYCR Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR SILVERADO - XV17ATYR Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR S - XV17ASYB Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR MIDNIGHT WARRIOR - XV17PCMYC Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR - XV17ASC Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR WARRIOR - XV17PCSC Electrical - 2
Yamaha Motorcycle 2008 ROADLINER S - XV19SXCW Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR - XV17AWXCW Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR SILVERADO - XV17ATSXCS Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR WARRIOR - XV17PCXCR Electrical - 2
Yamaha Motorcycle 2008 STRATOLINER S - XV19CTSXCW Electrical - 2
Yamaha Motorcycle 2008 STRATOLINER S - XV19CTSXW Electrical - 2
Yamaha Motorcycle 2008 RAIDER - XV19CXR Electrical - 2
Yamaha Motorcycle 2008 RAIDER - XV19CXCR Electrical - 2
Yamaha Motorcycle 2008 RAIDER - XV19CXB Electrical - 2
Yamaha Motorcycle 2008 RAIDER - XV19CXCB Electrical - 2
Yamaha Motorcycle 2008 RAIDER S - XV19CSXL Electrical - 2
Yamaha Motorcycle 2008 RAIDER S - XV19CSXCL Electrical - 2
Yamaha Motorcycle 2008 RAIDER S WFLAMES - XV19CSXCR Electrical - 2
Yamaha Motorcycle 2008 RAIDER S with Flames - XV19CSXR Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR SILVERDO S - XV17ATSYG Electrical - 2
Yamaha Motorcycle 2009 ROADLINER MIDNIGHT - XV19MYC Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR - XV17AWYR Electrical - 2
Yamaha Motorcycle 2009 ROADLINER S - XV19SYG Electrical - 2
Yamaha Motorcycle 2007 ROADLINER S CA - XV19SWC Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR WARRIOR WITH FLAMES - XV17PCW-F Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR MIDNIGHT CA - XV17AMWC Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR MIDNIGHT SILVERADO CA - XV17ATMWC Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR MIDNIGHT - XV17AMW Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR SILVERADO CA - XV17ATWC Electrical - 2
Yamaha Motorcycle 2003 XV1700 ROAD STAR WARRIOR (CA Ed.) - XV1700PCRC-B Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR SILVERADO Two-Tone - XV17ATTC Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT WARRIOR - XV17PCTB Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT SILVERADO - XV17ATMT Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR (cast wheels) - XV17AWTC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR MIDNIGHT SILVERADO - XV17ATMV Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR MIDNIGHT - XV17AMV Electrical - 2
Yamaha Motorcycle 2006 ROADLINER S - XV19SV Electrical - 2
Yamaha Motorcycle 2006 ROADLINER MIDNIGHT CA - XV19MVC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR SILVERADO CA - XV17ATVC Electrical - 2
Yamaha Motorcycle 2017 RAIDER - XV19CHB Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR (spoke wheels) Two-Tone - XV17AT Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR SILVERADO Two-Tone - XV17ATT Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT WARRIOR (Onyx) - XV17PCT Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR (cast wheels) - XV17AWT Electrical - 2
Yamaha Motorcycle 2014 RAIDER S - XV19CSEL Electrical - 2
Yamaha Motorcycle 2014 RAIDER S - XV19CSECL Electrical - 2
Yamaha Motorcycle 2014 RAIDER SCL - XV19SCLE Electrical - 2
Yamaha Motorcycle 2014 RAIDER SCL - XV19SCLEC Electrical - 2
Yamaha Motorcycle 2014 STRATOLINER DELUXE - XV19CTFECR Electrical - 2
Yamaha Motorcycle 2014 ROAD STAR SILVERADO S - XV17ATSEG Electrical - 2
Yamaha Motorcycle 2014 RAIDER - XV19CER Electrical - 2
Yamaha Motorcycle 2014 RAIDER - XV19CECR Electrical - 2
Yamaha Motorcycle 2013 ROAD STAR S - XV17ASDCB Electrical - 2
Yamaha Motorcycle 2013 ROAD STAR SILVERADO S - XV17ATSDCL Electrical - 2
Yamaha Motorcycle 2013 ROADLINER S - XV19SDB Electrical - 2
Yamaha Motorcycle 2013 STRATOLINER S - XV19CTSDCL Electrical - 2
Yamaha Motorcycle 2013 STRATOLINER S - XV19CTSDL Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR - XV17AWW Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR WARRIOR - XV17PCW Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR MIDNIGHT WARRIOR - XV17PCMW Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR CA - XV17AWWC Electrical - 2
Yamaha Motorcycle 2007 STRATOLINER MIDNIGHT CA - XV19CTMWC Electrical - 2
Yamaha Motorcycle 2007 STRATOLINER CA - XV19CTWC Electrical - 2
Yamaha Motorcycle 2007 ROADLINER MIDNIGHT - XV19MW Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR CAST - XV17AWV Electrical - 2
Yamaha Motorcycle 2006 ROADLINER MIDNIGHT - XV19MV Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR WARRIOR CA w-flames - XV17PCVC-F Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR WARRIOR - XV17PCV Electrical - 2
Yamaha Motorcycle 2006 STRATOLINER MIDNIGHT CA - XV19CTMVC Electrical - 2
Yamaha Motorcycle 2006 STRATOLINER MIDNIGHT - XV19CTMV Electrical - 2
Yamaha Motorcycle 2006 STRATOLINER S CA - XV19CTSVC Electrical - 2
Yamaha Motorcycle 2006 STRATOLINER S - XV19CTSV Electrical - 2
Yamaha Motorcycle 2006 ROADLINER - XV19V Electrical - 2
Yamaha Motorcycle 2003 ROAD STAR WARRIOR - XV1700PCRC Electrical - 2
Yamaha Motorcycle 2009 ROADLINER MIDNIGHT - XV19MY Electrical - 2
Yamaha Motorcycle 2009 ROADLINER S - XV19SYR Electrical - 2
Yamaha Motorcycle 2009 STRATOLINER - XV19CTYS Electrical - 2
Yamaha Motorcycle 2009 STRATOLINER S - XV19CTSYR Electrical - 2
Yamaha Motorcycle 2009 STRATOLINER - XV19CTYCS Electrical - 2
Yamaha Motorcycle 2009 STRATOLINER S - XV19CTSYL Electrical - 2
Yamaha Motorcycle 2010 RAIDER S - XV19CSZCB Electrical - 2
Yamaha Motorcycle 2010 RAIDER S - XV19CSZB Electrical - 2
Yamaha Motorcycle 2010 RAIDER - XV19CZR Electrical - 2
Yamaha Motorcycle 2010 RAIDER - XV19CZCS Electrical - 2
Yamaha Motorcycle 2010 RAIDER - XV19CZCR Electrical - 2
Yamaha Motorcycle 2010 RAIDER S - XV19CSZL Electrical - 2
Yamaha Motorcycle 2010 RAIDER S - XV19CSZCL Electrical - 2
Yamaha Motorcycle 2012 STRATOLINER DELUXE - XV19CTFBCS Electrical - 2
Yamaha Motorcycle 2012 ROADLINER S - XV19SBCG Electrical - 2
Yamaha Motorcycle 2012 ROAD STAR SILVERADO S - XV17ATSBCW Electrical - 2
Yamaha Motorcycle 2012 ROAD STAR S - XV17ASBCB Electrical - 2
Yamaha Motorcycle 2011 STRATOLINER DELUXE - XV19CTFAB Electrical - 2
Yamaha Motorcycle 2011 ROAD STAR S - XV17ASAB Electrical - 2
Yamaha Motorcycle 2011 RAIDER - XV19CACO Electrical - 2
Yamaha Motorcycle 2011 RAIDER - XV19CAO Electrical - 2
Yamaha Motorcycle 2011 RAIDER S - XV19CSAL Electrical - 2
Yamaha Motorcycle 2011 RAIDER S - XV19CSACL Electrical - 2
Yamaha Motorcycle 2011 RAIDER S - XV19CSACB Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR MIDNIGHT WARRIOR CA - XV17PCMXC Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR S - XV17ASXS Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR SILVERADO CA - XV17ATXLC Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR - XV17AWXCL Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR WARRIOR - XV17PCXR Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR MIDNIGHT WARRIOR - XV17PCMY Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR S - XV17ASYCB Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR SILVERDO S - XV17ATSYCG Electrical - 2
Yamaha Motorcycle 2008 STRATOLINER S - XV19CTSXR Electrical - 2
Yamaha Motorcycle 2010 ROADLINER S - XV19SZL Electrical - 2
Yamaha Motorcycle 2008 ROADLINER S - XV19SXCR Electrical - 2
Yamaha Motorcycle 2010 STRATOLINER DELUXE - XV19CTSZCB Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR MIDNIGHT SILVERADO - XV17ATMSC Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR MIDNIGHT - XV17AMS Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR SILVERADO - XV17ATSC Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR - XV17AS Electrical - 2
Yamaha Motorcycle 2015 RAIDER S - XV19CSFCR Electrical - 2
Yamaha Motorcycle 2015 RAIDER BULLET COWL - XV19CFCB Electrical - 2
Yamaha Motorcycle 2015 RAIDER - XV19CFGY Electrical - 2
Yamaha Motorcycle 2015 RAIDER S - XV19CSFR Electrical - 2
Yamaha Motorcycle 2015 RAIDER - XV19CFCGY Electrical - 2
Yamaha Motorcycle 2014 STRATOLINER DELUXE - XV19CTFER Electrical - 2
Yamaha Motorcycle 2003 XV1700 ROAD STAR WARRIOR - XV1700PCR-B Electrical - 2
Yamaha Motorcycle 2006 STRATOLINER - XV19CTV Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR CAST CA - XV17AWVC Electrical - 2
Yamaha Motorcycle 2006 ROADLINER S CA - XV19SVC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR WARRIOR CA - XV17PCVC Electrical - 2
Yamaha Motorcycle 2006 ROADLINER CA - XV19VC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR MIDNIGHT WARRIOR - XV17PCMVC Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR SILVERADO - XV17ATV Electrical - 2
Yamaha Motorcycle 2006 ROAD STAR SPOKE - XV17AV Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT - XV17AMT Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR WARRIOR w-flames - XV17PCT-F Electrical - 2
Yamaha Motorcycle 2004 ROAD STAR WARRIOR - XV17PCS Electrical - 2
Yamaha Motorcycle 2005 ROAD STAR MIDNIGHT SILVERADO - XV17ATMTC Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR MIDNIGHT SILVERADO - XV17ATMW Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR CA with flames - XV17AWWC-F Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR WARRIOR CA - XV17PCWC Electrical - 2
Yamaha Motorcycle 2007 STRATOLINER S - XV19CTSW Electrical - 2
Yamaha Motorcycle 2007 STRATOLINER - XV19CTW Electrical - 2
Yamaha Motorcycle 2007 STRATOLINER S CA - XV19CTSWC Electrical - 2
Yamaha Motorcycle 2007 STRATOLINER MIDNIGHT - XV19CTMW Electrical - 2
Yamaha Motorcycle 2007 ROADLINER CA - XV19WC Electrical - 2
Yamaha Motorcycle 2007 ROAD STAR with flames - XV17AWW-F Electrical - 2
Yamaha Motorcycle 2007 ROADLINER - XV19W Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR MIDNIGHT WARRIOR - XV17PCMX Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR S CA - XV17ASXSC Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR SILVERADO - XV17ATXL Electrical - 2
Yamaha Motorcycle 2008 ROAD STAR SILVERADO S (Dark Bluish Gray Metallic 8) (CA Ed.) - XV17ATSXSC Electrical - 2
Yamaha Motorcycle 2008 STRATOLINER MIDNIGHT CA - XV19CTMXC Electrical - 2
Yamaha Motorcycle 2008 STRATOLINER S - XV19CTSXCR Electrical - 2
Yamaha Motorcycle 2008 ROADLINER MIDNIGHT CA - XV19MXC Electrical - 2
Yamaha Motorcycle 2008 ROADLINER S - XV19SXW Electrical - 2
Yamaha Motorcycle 2010 ROAD STAR SILVERADO - XV17ATZCW Electrical - 2
Yamaha Motorcycle 2010 RAIDER - XV19CZS Electrical - 2
Yamaha Motorcycle 2010 ROAD STAR S - XV17ASZB Electrical - 2
Yamaha Motorcycle 2013 RAIDER - XV19CDCB Electrical - 2
Yamaha Motorcycle 2013 ROAD STAR S - XV17ASDB Electrical - 2
Yamaha Motorcycle 2013 RAIDER S - XV19CSDCR Electrical - 2
Yamaha Motorcycle 2013 RAIDER S - XV19CSDR Electrical - 2
Yamaha Motorcycle 2013 RAIDER S - XV19CSDCW Electrical - 2
Yamaha Motorcycle 2013 RAIDER - XV19CDB Electrical - 2
Yamaha Motorcycle 2013 RAIDER SCL - XV19SCLDC Electrical - 2
Yamaha Motorcycle 2013 RAIDER S - XV19CSDW Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR SILVERADO - XV17ATYCR Electrical - 2
Yamaha Motorcycle 2009 ROAD STAR WARRIOR - XV17PCYCS Electrical - 2
Yamaha Motorcycle 2009 ROADLINER S - XV19SYCR Electrical - 2
Yamaha Motorcycle 2012 RAIDER S - XV19CSBB Electrical - 2
Yamaha Motorcycle 2012 RAIDER S - XV19CSBCP Electrical - 2
Yamaha Motorcycle 2012 RAIDER S - XV19CSBCB Electrical - 2
Yamaha Motorcycle 2012 RAIDER - XV19CBCS Electrical - 2
Yamaha Motorcycle 2012 RAIDER SCL - XV19CBO Electrical - 2
Yamaha Motorcycle 2012 RAIDER S - XV19CSBP Electrical - 2
Yamaha Motorcycle 2012 RAIDER - XV19CBS Electrical - 2
Yamaha Motorcycle 2012 ROAD STAR S - XV17ASBB Electrical - 2
Discussion Starter · #8 ·
I think thisifht be what happened I pulled the headlight out took out the ignition and left the cover off of it so I could turn with pliers with the key broken in it. I rode it 2 hours home then went to go get something to eat and just died in McDonald's parking lot with lights and everything on. Then tried to restart but nothing when I push the start button
Yes the tach goes up the. Down as normal. And yes the ful pump comes on
Extract the broken off portion of the key by turning it all the way back to the off position. You might now be able to turn back further than off so be gentle. As mentioned above, use something like a pick or an eyeglass-screwdriver to capture a tooth and lift enough to grab with tweezers or needle nose pliers.
Once the broken remnant is out the switch might still work as normal if no damage has been done to it.
1 - 9 of 9 Posts
