1 - 3 of 3 Posts
I'm in the middle of installing these pipe and noticed that the rear pipe is touching the stator. Is this going to cause problems or do I need to get the Dremel out? I think 1/16" would do the trick. It's a shame that I have this problem right out of the box. Any ideas???
Discussion Starter · #3 ·
paintshakerdave said:
Did you use the provided spacers? Did you get it new ? you should have a parts kit with them.
Yes I bought it new, however I don't see what the spacers have to do with it. I have 3 sets of spacers (1 set for the rear brake master cylinder, 1 set for the mounting bracket, 1 set for the rear brake reservoir). None of which are near the stator...
1 - 3 of 3 Posts
