1 - 4 of 4 Posts
I just purchased the patrick racing Hi-Flo air filter. I cant aford the power comander yet. Can I run this with a roadstar pipe with out hurting anything? I heard if you adjust the ecu it only afects the low rpm range. Thanks for your help
Yes, you can. Adjusting the ECU affects the entire rpm range. If you want to get everything out of it, a pc3 is the way to go, since it is capable of making adjustments at individual rpm points, but with just an air kit and a pipe, you can get away with tweaking the ECU.
I ran it for a while on the midnight without adjusting the ECU and it ran just fine. A little lean and you wont get all the power possible.
1 - 4 of 4 Posts
