  • Voting Now Open for the Warrior of the Quarter Challenge! Vote HERE
1 - 11 of 11 Posts
· Administrator/Super Moderator
Yes, can't get past the pivot point without removal
· Registered
Sorry, my one word response was less than helpful.
Yes, you have to pull the pivot bolt. On my bike that means dropping the exhaust, starboard footrest and brake links. I take the wheel off as well. You don't have to, but it makes things easier going back together. Under the front pully cover four bolts that hold the T-case to the frame, and you're ready.
have fun...
· Registered
2007 Yamaha Road Star Warrior XV1700PC
Thanks for info
Or using a lift, you keep the rear wheel on the ground, pull the swingarm axle out, then raise the bike just high enough to create a gap to get the belt through. You still have to remove the T-case at the pulley housing and/or exhaust and peg if necessary but you don't have to mess with the suspension and just loosen the wheel.
· Registered
2007 Yamaha warrior
Discussion Starter · #8 ·
My Bsc swingarm and rim should be ready soon I was looking at what I needed to do take oem swingarm off. So I can start tricking this bike out. Thanks for the info
· [Retired Admin-SuperMod]
That seems like it's a pulley-tooth-killer.
Years ago I got this Emergency Drive Belt -
H.D. #40171-97 ('95-'99 USA Softail).
Never had to use it.
It seems like a pita solution but better than nothing. The instructions pdf is out there on the net. Maybe these are still made. Dunno.
HD dealers used to stock them.
Google popped up with:
· Registered
I have that belt also AZ W I keep it in my bag for longer trips ,but never had to use it knock on wood.
1 - 11 of 11 Posts
