1 - 5 of 5 Posts
im changing my bars and i want to re-use all the stock controls.. do i need to replace the throttle or is it re-usable?
depends on what kind of bars you got. if its the same diameter than you can reuse all your stock controls,i got yamaha ttbars and have all the stock controls
You can use your stock controls. If you go with TT style drag bars make sure you purchase some that allow internal wiring. It cleans up the looks considerably.
+1
Most if not all bars made for the warrior will come down to 1" in the control area so you can use your stock control with no problems....
The only problem you might come across would be the need to extend your wires to acomodate to the diference in bar length rise/pullback or internal wiring.
the bars are one-offs that i had to drill for the wiring and then have powder coated. they look great. im just waiting on new risers and i will be ready to get to it.
1 - 5 of 5 Posts
