1 - 7 of 7 Posts
I have a 2008 Warrior with a check engine light on. I went through the diags and DI 61 shows "00". DI 62 shows 01 so I tried hitting the engine off switch and turning it back on and it won't go to 00. Has anyone seen this before?
Thanks in advance,
Bill
Make sure your vacuum lines are connected good going to the sensors. That will cause the engine light to stay on.
When running, on the tach all I see is the time, odometer/trip and the RPM readout. (and of course the check engine light)
I will pull the tank and re-check the vacuum lines. I just picked up the bike last week from a friend who bought it new. He removed the stock air box and installed K&N's. He also put on a 2-->1 Vance & Hines pipe. Sounds real nice. There is also a Cobra FI2000 PowrPro to accommodate the extra air flow. I did disconnect the tuner to test but still have the light.
1 - 7 of 7 Posts
