clutch problems, noise?
1 reading
1.2K views 16 replies 6 participants last post by  ridingrules
[/emoticons/emotion-6.gif!]Has anyone had a clutch fail on them yet? Mine started making a whining noise that's proportional to engine speed coming from inside the case on the left side. It still works fine and doesn't feel any different performance-wise, but it sure does sound like something's about to go out. Bearing maybe? kinda sounds like that.[/emoticons/emotion-6.gif!]
#2 ·
I could be way off here, but I had a similar noise that I though was coming from the belt drive. I tried everything to track it down. I finally ended up looseining off the rear axel and the noise ceased to exist. Worth looking at anyway. Cheap and easy to check, espescialy if you have a good stand.
#8 ·
Thanks for the part # gunny. I think I'm going to stop by the shop on the way home today and let them take a look. I just wanted to know if anybody else had a similar issue and what might be the cause. I don't want them telling me I need a new transmission, or piston rings, or continuum transfunctioner or some crap like that.......I think that would put me over the limit on stupid people I can kill for the year.
#9 ·
If you clutch is not adjusted properly and not completely disengaged it would ride on the bearing all of the time. The bearing is only designed to have pressure on it when the clutch is pulled in. That is how a car works anyway. Same thing happens if you ride the clutch a lot like my wife.
#13 ·
Ok, so I leave the office on the way to the yamaha shop and this guy pulls up next to me in traffic. He leans out the window and says, "man that don't sound too good." It was that loud. So I get to the shop, no noise. The guy at the shop takes it for a ride.....you guessed it, no noise.
So I just brought it home. I'm not quite sure what to do at this point.
