OK, in this little beach community even the Cobra pipe was too loud. I tried packing with everything but didn't do any good. Finally took out the baffle, cut a slot in the pipe about half way back and slipped a washer in. Now the pipe is just a hair louder than the stock pipe and has the looks of an aftermarket pipe. Best of both worlds, as far as I'm concerned. I'm sure the back pressure will will reduce some horsepower and now I can hear the sucking of the BAK again, but worth the price in order to drive where I want to. I suspect the pipe will get a lot hotter in the area before the washer so I may have some problems with bluing. I'll cross that bridge when or if I get there. For those of you old enough to remember the old Honda 305 Scramblers, I'm thinking about a washer type setup that like the old aftermarket setups for the Scramblers, you could turn a adjusting nut that would turn that washer sideways when you wanted noise and the other way when you wanted it quiet.
Moved to Mod forum by CarKNee
