Codes
1.5K views 10 replies 8 participants last post by  Buflow
Hey warriors wuzuup,Went on a ride to night and in about 15 minutes into ride my bike shut down. when i pulled over it was spitting out codes 11-15-30 on the digital readout. after sitting for 5-10 minutes, the bike would restart. again after 15 minutes, my bike stalled again. this cycle happened three times tonight and came home to park it. does anyone know what these codes mean??? help bad1700
#2 ·
Code 11 - No normal signals are received from the cylinder identification sensor.
Code 15 - Throttle position sensor - open or short circuit detected.
Code 30 - The motorcycle has overturned.
Sounds like you have an electrical problem. Make sure your battery's ground cable is connected, and tight! Also check to make sure your fuses are firmly seated, as well as the ECU main wiring harness. Looks like you've done a few mods, so anything's possible. Maybe pulling the tank and giving all the BAK related sensor relocate connections a good once over is in order...
#9 ·
Ok- see if you can find a wiring diagram, sounds like the reference voltage feed is shorting out , or the ground is loose. You need to find out what these sensors share in common (and what conditions are needed to set the codes/what sensors are involved). The fact that 3 codes are setting at once is telling me the odds on 3 sensors failing simultaniously are pretty high. I would start by doing a visual inspection of all the wiring harnesses (paying particular attention to the areas where modifactions were done/ recent work performed).
#11 ·
Just a shot in the dark but have you in recent history disconnected the ECU?
It almost sounds like you've got a pushed pin or two. Is it possible that when doing an ECU reprogram you forgot to reset the white bars and then when the ECU got plugged back in some one or more of the pins pushed out?
