Ok, here's the story, I'll try to keep it short:
Bike has been very low at idle for a while, didn't worry me, just creeping down each time I used it. Parked up at work and started bike, got an Error 2 on display just before it started - (atmospheric pressure in manual). it was very cold and foggy that day, so I put it down to extreme conditions.
Next day, low idle replaced by high idle, about 1.4k, not happy about that, so thought I'd better look into that atmospheric pressure thing and also check my LCV connections, look for leaks etc.
Tried bike again, still high idle, now its giving me a TPS code 15 (if I remember correctly) I happened to have a spare TPS, so I connected that up, idle seemed slightly better - (maybe pot luck on how I positioned it) daylight was going, so I figured it would have to do for today - would perhaps revisit and figure out how to set up that TPS properly later in week.
Go fetch helmet for test ride, warning light appears, error 12 CPS. - Can't figure out wether to believe that or not, seemed to run fine down to petrol station and back.
Engine idle is still a bit high at 1100k revs, can't lower it with the adjuster knob under seat, its already off the scale (resting position on throttle bodies) It did come down slowly to nearer 900 by time I got home
Also - I noticed when I turned off the engine, I hear a ratchet sound in the LCV - could that be the source of all my problems? ie: operating at higher revs due to choke stuck in on position? I don't normally hear it ratchet like that.
Can I pull off the hoses and squirt oil in there? Would that help to free any mechanical parts, or would that simply damage rubber seals or whatever it's got in there?
Any other tips, suggestions, etc? I'm pretty stumped with electrics, I think things go a bit haywire at times due to age - for instance, I re-routed some cables behind the coils and caused havoc earlier this year till I got them freed up - lot of pinched cables etc on the loom.
