Thanks for all the help and advice, I may have solved the current problem - after diddling about with this and that, I noticed the rear right side spark plug lead was loose & barely on the plug, probably after I last lifted the silencer box and didn’t push it back down properly - if that turns out to be the cause, I’ll find out tomorrow I guess when I go for a fully cold start.
Today I checked the oil temperature sensor and the engine temperature sensor, they tested as 24.7 and 25.4, so since they are both giving similar reading, I assume they are ok (tested at x200 ohms)
I took the silencer box off, and ran the engine, the inlet pipe from the LCV - silencer box was sucking pretty hard, after 20 mins warming up, it had lessened dramatically, (tho still sucking very slightly) so I assume this means the LCV is doing its job. Tick over was still low despite the LCV so I pushed it up to about 900revs so it would idle ok, then after 10 mins or so had to drop is down from about 1500 revs back to about 900.
Normally I would expect that since the tick over is raised by the LCV, if you set it at 900rpm, it would drop as the LCV deactivates, dropping the tick over to about 600rpm, so you would have to then raise it back up for normal temperatures. Consequently I can only assume something is still not right!
I went for a test ride, all seemed well, but then it was when the engine was warm the other day.
Perhaps of interest - I found that the clamp between the air silencer box and throttle bodies has stripped threads, tightening and loosening has no effect, so could be a leak there, ordered a new one, but seriously I don’t think its too bad.
I did the double press while switching on, and the 2 second follow up press and got a 15 - so I thought hellfire, its a TPS error code, after much flapping around, I realised this is not an error code, the TPS reading is 15 - 92, not perfect, but ptobably not a real issue - I assume I’m right there?
I ran diagnostics on both the cold engine and the hot
Thanks for all the help and patience!
Diag
D1.01 13
D1:02. 99
D1:03. 0
D1:04. 0
D1:05. 37
D1:07. 0
D1:08. 0.6
D109. 11.3
D1:10. 48
D1:11. 46
D1:20. On
D1:21. On
D1:30. 00
D1:31. 00
D1:36. 00
D1:37. 00
D1:50. 00
D1:52. 00
D1:54. 00
D1:55. 3.4
D1:60. 00
D1:61. 23
D1:62. 2
D1:70. 0
Hot engine. (suspect I got out of sync with records below) [EDIT] think I just corrected that sequence
D1.01 15
D1.02. 99
D1.03. 0
D1.04. 0
D1.05. 64
D1.07 0
D1.08. 0.6
D1.09. 11.6
D1.10 120
D1.11 162
D1.20. On
D1.21 On
D1.30. 0
D1.31. 0
D1.36. 0
D1.37. 0
D1.50. 0
D1.52. 0
D1.54. 0
D1.60. 1.9
D1.61. 0
D1.62. 22
D1.70 2
Hoping I can report back tomorrow to say the bike ran no problems cold in the morning, but I shall be (pleasantly) surprised if it does - here's hoping!
