Yamaha 90891-30047-00 PICK UP KIT even available on Amazon ... $16.39 Landed to your doorYa I've looked for both the cps and pick up but can't find them. Should I get sensor and wire or are they together?
You could remove the lower fuel tank to get the access you need.
I did not.
I cut and abandoned the original wire. Then, fished the new wire up through the frame with a coat hanger. Remove the horn, and LAS for better access at the bottom.
You can do as Ken suggested or you can extract the 2-wires from the new CPS connector.So I am working on replacing my CPS, but for the life of me I cannot figure out how I am going to get that wire routed up through the frame and into the under seat area where it plugs in. Any tips on that part? I have the case off of the engine, oil drained and all that but I am stuck on the routing. I haven't pulled the old sensor out yet because I was thinking that maybe I could tie the old one to the new one and be able to pull the new one up as the old gets yanked. Make sense?
Is there an easier way to get it routed? I also see that it is zip tied to the frame and I am not sure how to get to that zip tie either or replaced it at that. I feel like I am missing something. Any help is greatly appreciated!
Thank you,
Pnedac
