1 - 6 of 6 Posts
Power Commander USB 3 does not accept maps from CD and from PC USB3
home page. And shows error message window containing -> (Error sending Power Commander map /
Incompatible map version (120 != 12800)).
Software recognizes device, shows throttle position and serial number and RPM, but bike works only on rear cylinder.
I used to work with device like this (not that i have now) on other
bike (Yamaha Warrior), and it worked just fine.
Does anyone have solution for this problem?
I have suspicion that PC USB 3 is fake, could it be?
you can reset the PC111usb then it will be set back to fctory settings with a zero map they have instructions on this at the Dynjet web site
thanks, but PC111 was damaged returned it to seller in Germany. Serial nr. on device core was different from nr. displayed in software.
That's the first time I've heard of that problem.I'm glad it finally worked out for you.
Maybe the Firmware is damaged and needs to be re-uploaded into the PCIII...check their website.
1 - 6 of 6 Posts
