Decomp Solenoid Click Conditions
1.8K views 10 replies 7 participants last post by  DeWarrior
The other weekend I cut off my mud flap, removed the license plate light, and moved the license plate up. I plan on installing a strip LED wired to the existing license plate light wires, but have not done so yet. The only change I have made to the electrical system on the back end is removing the plate light. The next time I rode the bike and then shut it down that darn decompression solenoid started clicking. That thing is LOUD!
So, I did some experimenting and this is what I found. If you use the engine cut off switch to shut the bike down OR if the bike is not in neutral when you shut down, click click click... If you put the bike in neutral then shut it down with the key there is no clicking and no other weird problems. How weird is that?
#5 ·
Pulled mine off when I first got the bike and did not have any problem, but when I replaced the stock front signals with the Kuryakyn Silver Bullets, I experienced this same problem as have several others when replacing the front signals. Some have installed resistors. Some have soldered an extra bulb in to pull more amps and stuck it in the headlight housing. Some are just living with it and shutting the bike off in neutral and not parking on any hills.
#9 ·
Thanks for the info. From the get go I was planning on installing a strip LED (hasn't arrived yet but I just couldn't wait to chop off that mud flap), and hoping that this alone would prevent the problem. If it doesn't I'll install the strip LED and the indicator light as Dark Star suggested.
#10 ·
For your Information. Each individual x 4 TurnSignal/Running light draws 25watts 7.5ohms to operate correctly, so with this information if you decide to change over to LED's you need to draw the proper amperage in order for the on board computer to function properly. With my set up, MDWright Integrated Tail Light and Signal Dynamic's front turnsignals/running lights I have a total of 4 - 25watt 10ohm resistor's running my system with no problems.
#11 ·
Thanks for the info Darkstar. I am aware of the issues with using LEDs for turn signals and have already installed LED signals up front successfully. At this time I do not plan on using LED signals on the back. I am only using LEDs for the plate light. As far as I recall from reading the many threads related to LED installs load equalization should not be an issue when replacing just the plate light. Is this correct?
