PROBLEM SOLVED--SEE LATER POST
Previously did AIS removal. Did VBAK yesterday. Immediately noticed bike started roughly and than continuously surged at idle between 1000 and 1200 rpm. Test rode bike. Surging very badly at low speeds. Roll on very abrupt. Backfiring. Accelerates from mid-rpms to upper OK but still not right. Checked all connectors, hose connections---everything looks good. I previously capped the left throttle body nipple when doing the AIS removal--that is the ONLY nipple or port that I blocked. I have not made any adjustments and plan to do the Ivan Flash. Is this normal when doing the VBAK mod and will the Flash fix it? Perhaps I overlooked something when doing the VBAK---what should I be checking for? Running PCS Roadster exhaust with their Vortex race baffle (almost straight pipes). I never did disconnect any of the three sensors or their hoses--just unbolted them, pulled them aside, then zip-tied them in place. Bike ran perfectly before I did the VBAK. Any advice or suggestions greatly appreciated.
