Why did he say to disconnect it?
Your bike has 2-2 shorty exhaust.
What intake set-up? Stock?
Zachary, Please post your results after you try it both ways. I have the Cobra Black unit and am also considering Ivans Flash. The Cobra unit comes with a baseline setup for stock engines with less restrictive exhausts and air intakes--then it makes real-time adjustments off of this baseline. It only makes adjustment to the air/fuel. It is my understanding that Ivans flash does much more but I have no knowledge of how they work together--but I'm sure Ivan does. The Cobra unit is working well for me. I didn't have a big problems to begin with but with a couple of small adjustments I was able to eliminate most back-firing and popping on decel. Bike does run smoother and stronger. It will be interesting to hear your results with both (or anyone else who may have used both).Ivan told me to disconnect the Cobra tuner when he flashed my ecu. I haven’t ridden it yet ‘cause winter but I plan to try it both ways
He told me the same thing but from what I've heard talking to a few members that have it currently is that it runs really good with both together.Ivan told me to disconnect the Cobra tuner when he flashed my ecu. I haven’t ridden it yet ‘cause winter but I plan to try it both ways
Thanks Arizona---That was the conclusion that I was coming to from the research that I have been doing. Thanks for confirming. So in conclusion: It seems the best approach would be to do Ivans Flash first , ride the bike, if no issues are found--then you are good. As Arizona says if you still have the other issues he listed above you will need to then get a fuel manager. I did it the other way around and installed the Cobra Black unit first and it has worked out well for me. But I'm still considering Ivans Flash also. Side note: One of the things that the Flash will do for you is to raise the rev limit to 5850 rpm in every gear--a fuel tuner will not do that.Ivan's changes tuning parameters not air:fuel ratio. IT IS TOTALLY DIFFERENT FROM A FUEL MANAGER. Depending on your motor mods including intal and exhaust mods you WILL have to re-adjust air:fuel.
Some of the parameter changes do help the tuning to cope marginally with some mods. But not 100%.
Ivan's will work 100% on a 100% stock motor with stock intake and exhaust.
Ivan's will work pretty well with a 100% stock motor that has just a modified intake iron a modified exhaust. To rid backfiring or pop-up-the-intakes or hesitation or overheating or surging you must address air:fuel. That REQUIRES a fuel manager.
So once you had read this you cannot complain later that nobody told you.
Separate: the CobraCVT is different from all other Cobra tuners.
I believe he said it was not needed and would just use more fuel. He said disconnect or zero out the tuner. Actually asked me to repeat it to him when we talked again for payment. VBAK K&N cone filtersWhy did he say to disconnect it?
I sure will, I’m excited to ride it. I have the same tuner btw. It definitely helped.Zachary, Please post your results after you try it both ways. I have the Cobra Black unit and am also considering Ivans Flash. The Cobra unit comes with a baseline setup for stock engines with less restrictive exhausts and air intakes--then it makes real-time adjustments off of this baseline. It only makes adjustment to the air/fuel. It is my understanding that Ivans flash does much more but I have no knowledge of how they work together--but I'm sure Ivan does. The Cobra unit is working well for me. I didn't have a big problems to begin with but with a couple of small adjustments I was able to eliminate most back-firing and popping on decel. Bike does run smoother and stronger. It will be interesting to hear your results with both (or anyone else who may have used both).
I have a tuner and replaced the plugs, they looked pretty good surprisingly. The bike is running better with each ride. I suspect this bike lived a hard life before I got it. Excited to try the new flash once we warm up here.@Zachary Hazard
With BAK or VBAK and 2-2 shorties you get excellent improvements in free air flow and will need a fuel manager to maintain air:fuel, with or without Ivan's. Otherwise it's going to run lean. I expect it will pop and backfire.
You could observe it by 'reading' your spark plugs and noticing excess heat. It's good to observe for yourself because in the worst cases pistons melt in their jugs from super-lean conditions (because the injected volume of fuel is also the cylinder's coolant).
Engineering and mother nature demand a balanced air:fuel ratio in order for internal combustion to work effectively and efficiently. There are some good spark plug reading charts in Documentation (see the Table of Contents).
