1 - 5 of 5 Posts
well picked up my warrior saturday morning after the dealer told me it is ready they did install the high compression pistions they did not charge me for that but i did slip the mechanic a hundo for taking that extra special care for working on my baby now when i romp on it between 60 and 70 i hear a squeekin metallic noise sounds like its coming from under the tank i yanked off the tank and nothing seemed loose cant figure out what is wrong dealer closed on monday hope its something simple if any of you have any advice I sure could use it thanks
Maybe take a look at your front brakes, a friend kinnda had same noise as yours and after checking it that's what it was.
Ride it again n use front brakes to see if noise stops.
squeaking metallic noise....you just had the hc pistons put in? what octane gas is in the bike? did you fill it up with high octane? maybe your describing a little pre-ignition?
Definitely check the octane...otherwise maybe (hope not) the pistons or rings didn't seat correctly. Careful man...
1 - 5 of 5 Posts
