1 - 6 of 6 Posts
All the dang gas stations around hereare starting to useethonol in the gas. The pumps are stating E10 Ethonol blend. Has anybody had any problems with running ethonol blend gasoline?
nope, all the stations around here that I know of have run 10% etoh for the past few years. you should have no problem
I live in MN and I don't ever remember the gas not having 10% ethonol. I'm 27 years old, so I've only been driving for 11 years, so that tells you how far I go back. Anyways I've ran it in everything from cars and motorcycles, to lawnmowers and chainsaws. No problems at all. A lot of times the premium grade of fuel doesn't contain any ethonol. Most of the time when you see an engine have trouble with ethonol it's in a small gas engine, such as a weed wacker or a chainsaw. That would be the only reason I would purchase premium fuel for an engine that doesn't otherwise require it. So anyways 10% ethonol is nothing to worry about. 20% however would concern me. They're talking about bumping it up around here.
Check out these other previous threads concerning it as well for further opinions and info:
http://rswarrior.com/forums/p/25403/372355.aspx#372355
http://rswarrior.com/forums/p/22223/338390.aspx#338390
http://rswarrior.com/forums/p/117866/951640.aspx#951640
http://rswarrior.com/forums/t/21997.aspx?PageIndex=1
And discussed again last week.....
http://rswarrior.com/forums/p/119425/961018.aspx#961018
Basically the consensous is the 10% stuff is fine and has been around a pretty good while and nobody's noticed hardly. The E85 stuff is when people start noticing it seems especially in lawn movers and such. The search feature in the upper right can help you find answers to questions that have probably been discussed several times like this.
1 - 6 of 6 Posts
