Don't be fooled by the title. This system is far from being easy. Installation SUCKED! First off the actual fender stay bolts that come with the system need to be further out away from the fender stays. I added two small washers on the rear fender stays and one too the front fender stay bolts that came with the kit to accomplish this. These are not provided with the kit. Another problem once you commit to install there is no turning back. You have to drill holes through the saddlebags to attach the actual brackets to the bags. OK, no biggie, but I was not happy taking a drill to my $130.00 Saddleman Saddlebags. Once I completed the drilling I tried to put the bolts through and the bolt holes on the actual brackets and guess what? the **** holes are too small, so I redrill the holes to a slightly larger diameter. Then I proceed to install the brackets to the saddlebags and the bolts that they provided are like 1/2" too long. May not sound like much, but when you look in the bags and see how far those bolts stick through, it sucks! Definite snagging would be going on. So, again I head out to the hardware store to pick up shorter bolts. Mounted those **** brackets to the saddlebags, so far so good. NOT! Now, I try to mount these up on the Warrior and the actual brackets that are attached to my saddlebags do not line up with the fender stay bolts, provided with kit. The holes that were cut out for actual mating are off ever so slightly. Just enough not to allow for the Easy Brackets to slid down on the fender bolts (posts) So, once again I pull out my trusty Dremel and start fabricating the **** holes to get these to fit. All went well with refabricating and the Easy Brackets are now mounted on my Warrior and look **** good.
I Know I should have returned the Easy Brackets, but I have a RoadTrip planned for this weekend and wanted those **** Bags mounted! It was one thing after the other with the Easy Brackets. If I had to repurchase this item I would not. I would stick to the regular saddlebag guards that I originally purchased, so much easier and alot less frustrating.
UPDATE! No, I would not go back to the original saddlebag setup. The Easy Brackets are the Best. Might consider the Ghost Brackets as an alternative.Bump!
