Follow up on breakin. Man I'm really getting windy here. Oh well. The same theory holds true as to break in on plain bearings in the motor. Heat build up is what destroys the oil barrior between bearings and shafts. As a new motor is smoothing any high spots in shaft and bearing contact, these spots produce more heat. Higher rpm produces more heat in these areas, therefore they recomend lower rpms during break in. Ball and roller bearings do not really have a critical break in period, only the plain bearings. Your lower end may be already broke in but your upper end is not. Therefore , the breakin period. With todays technology in more accurate machining clearances and superior metalogy, break in is not as critical as it used to be. Still you want to seat those rings properly. A Warrior engine does not spin very fast rpm wise compared to others, but its piston speed is right up there. 5 grand on a Warrior is like 12 grand on a sport bike, the pistons are moving that fast at lower rpm's. They have to cover more distance(stroke) at the same rpm is why.A little note as far as honing the cylinders. When I was a mechanic for Honda in the eithties when the nicocell cyls came out, Honda told us not to hone. The rings will seat themselves. Kind of makes sense as the cylinder is so hard it does not wear much anyway. What you really don't want to do is scratch that cylinder more than you should. I know some of the mechanics would take some fine emery cloth and hand sand some crosshatch on them. Probably for their own peace of mind as it seems like the rings seated well without. KC.
