Thank you for that and all the work you and others did laying the groundwork for this mod (and all the others)! I have downloaded all the ECU Bump pdf’s from the documentation section and have read and re-read those and every post I could find. None of the threads have photos but I have seen a few by going into members’ galleries. It’s been helpful but still missing some detail here and there. I’ve put enough together to get started, though, and I’ve gotta do something about this lean cylinder… so, parts are on order and I’ll get busy this weekend to get her running in tip-top shape.IMO when a GOOD fuel manager is installed, the bump has limited value. I base this on the many many test bumps using my bump-switch for speed so I could ride-and-fly for many hours. The first data sets are still in my data pages. But all it does imo is reinforce what I just said.
Except one thing. Hesitation off idle when warm can be solved with a bump.
Ivan's doesn't tread on this part of the ECU. Be certain to write down settings before making changes. And imo list every change in order so you can backtrack without fiddling around if you overshoot the sweet spot.
I INSERTED A FRESH PDF INTO FIRST POST WITH PICS AND PARTS AND PRIOR MEMBER MODS FROM WHICH WE ALL STOLE IDEAS. I MIGHT HAVE MISSED SOMEONE SORRY IF I DID. MY INTENT IS JUST TO REPLACE LOST ATTACHMENTS AND BROKEN LINKS.
Sorry I did not realize the bits were gone.
BTW for those interested, the switch and cover continue to work perfectly. I added a rubber toggle switch boot way back at time of install. Closing the switch cover still cancels the switch from Bump mode into Run mode so there is no chance of issues. That being said, the bike appears to run just fine in bump mode or in disconnected mode. No difference noticed from Run mode. I've had no issues that cause any damage. Not even a hint of worry. Not that I push that as okay. But the couple times I accidently connected to nothing, the bike did not blow up and nothing happened. No dead battery. I mean nothing. But the blue toggle switch cover is still necessary and protects it all across every mile and bump and twistie.
That's EXACTLY what I'm looking for but I don't see ANY maps that specifically call out Ivan's Flash as one of the inputs (I would think this is important). It looks like everyone has just been emailing their maps around but no one has been sharing them in a central repository.RG I will say that I played with Ivan's, the bump and several maps to find the right combo. And the winning combo was Ivan's along with a custom map provided to me from a member named Steeda. This combo for me at least gave me literally the perfect storm. No more hot jugs, super crisp throttle response, never do I ever backfire and of course power throughout the rev range.
Well, I did a once over on my PC-III last night. Looked good. Connected it back up without issue.Yep! Love it! Hope you had most of that already typed up cause my response is going to be very lack-luster in comparison.
1. I do have a PC-III USB Ver 2
2. My map ran really well with my setup and wasn't corrupted at the time I "removed" it.
3. The PC-III is completely undamaged, just unplugged. I'll give it a once over when I reconnect it though.
4. EXCELLENT suggestion about viewing the map and verifying the lowest line covers the 850 range. THIS I WILL DO and wouldn't have known/thought about doing with you your guidance.
5. I'll plan to run it tomorrow to go to work and to get my front tire replaced. I'll make note of any issues and make sure my three buttons are zeroed out. I haven't used them and honestly wasn't sure what to do with them until doing all the reading lately.
6. I'm hopeful I'll be able to stop here:
"If your bike runs better then call it a day giving you time to learn more."
Otherwise, I'll continue with the rest of your suggestions. I'll definitely report back how it's running tomorrow as I'm looking to do a ride on Saturday and would prefer to not have to be d!cking around with it by then.
As always, thank you for your wisdom and encouragement. I'm glad I resurrected this thread! Looking forward to truly unlocking the beast!
Tuff choice. When I had my first Warrior purchased in 2004 I thought I was king of the World. I would ride with a bunch of Harleys and every bike night I had to defend my honor. I slapped a pro pipe and Church VBAK and got a dyno tune from a good friend of mine. I gotta search for the sheet but it laid down 88hp and 110tq. I was smoking everyone all day long with that simple combo and a 31 tooth pulley. Now it didn't have Ivan's but that tune was jjjjuuuusssssttttt right for that bike. I just ran.Or is that money better spent on an auto-tuner??
100% correct! I'm also a planner (at least mentally) where I'll think about everything that needs to be done and identify how it could go wrong, then correct that before I ever get started. My execution tends to go really well and I never find myself asking, "Why did I ever start this project??" But I'm also quite practical so if it make sense to move to the latest and greatest, I'm not going to be stubborn and just keep sinking money into a lost cause.
