Ever since installing my Bubs Chambermaids, first gear has felt a little flat. I couldn't really tell if it was not as quick or if it was just an illusion caused by all the extra sound. Hit second and the bike really jumped out so I wasn't too worried about it.
Followed the instructions posted here about how to reprogram the stock ECU. Grounded #27, went past the diagnostics menu to the Co display and made some changes.
Co1 was set to negative 1 and Co2 was set to negative 3. I seemed to see a trend where the rear cylinder on most of our bikes were set more negative than the front cylinder. I decided to go 4 up on both cylinders making Co1 positive 3 and Co2 moved up to positive 1.
Did some runs with the Butt Dyno and I have to admit I'm pretty darned impressed. The bike idles a little higher/smoother and is definately quicker with the improvement in first gears performance being quite noticable.
Different pitch to the exhaust note as well, sounds "less flat". Popping and the occasional backfire while backing down is gone now too.
I've found this Mod to be worth the money, oh wait, it was freakin free, then definately worth every penny. Two enthusiastic thumbs up.[/emoticons/emotion-1.gif]
