1 - 9 of 9 Posts
Help??? Anyone??? My 03 Warrior's engine light indicator always lights up, lights won't go off even when the bikes running, checked the oil etc.. everything seems to be ok. Any suggestions?
Thanks
quote:Originally posted by warstar
Are you getting any error codes on the tach?
No error codes....
quote:Originally posted by DarkStar
Is your idle set too low? Set idle at 950-1000rpm's. Gold/bronze colored thumb screw under seat near back of gas tank.
IT WAS LOW ABOUT 700-800 RANGE, i ADJUSTED IT TO THE 950-1000 RANGE, LIGHT INDICATOR STILL LIGHTS UP.... THANKS
nO WARRANTY HERE IN THE pHILIPPINES, BOUGHT IT FROM LOCAL IMPORTER HERE, BUT THE BIKE IS A CALI VERSION, I HAD A VANS AND HINES AND A COBRA FI2000 INTALLED, DON'T KNOW IF THIS HAS ANY EFFECT ON THE LIGHTS... THANKS
J.Opium......this thread was started 14 years ago. Start a new thread with your specific problems so we can help diagnose it properly. Have you tried running your codes
1 - 9 of 9 Posts
