1 - 10 of 10 Posts
Hi, Guys
Im from the netherlands and new here. Since a few weeks I am the prowd owner of a 2003 warrior wit 18k kms on it and in MINT condition. However I experienced a very weird and unlogical issue.
After drivink for a while I cam home and switched off the bike. A minute or so later i restarted it to drive it into my garage. When I kicked her in 1st gear it stalled... this went on for like 15 attempts of restarting and stalling, before the issue went away...
This happened 2 times now...
Does anyone have a clue what could be the cause?
Cheers!
Here is a pic btw
After driving for a while I cam home and switched off the bike. A minute or so later I restarted it to drive it into my garage. When I kicked her in 1st gear it stalled... this went on for like 15 attempts of restarting and stalling, before the issue went away...
Stalling and Cutting Out are two different things.
  1. A Faulty Kickstand Switch will behave exactly like using the Engine Cut-Off switch to shut-down the motor!
  2. An improperly adjusted clutch cable, Hot Engine, will cause the engine to labor & stall out!
Hey Alan, I never knew the kickstand actually had a switch... I might have had my kickstand extended... if that was the problem im LMAO... 😆😆😆
Discussion Starter #10
Yeah rub it it that its common... thanx bro... im so insecure allready... 😩😩
1 - 10 of 10 Posts
