Engine warning light?
1.7K views 19 replies 13 participants last post by  RH1700
My engine warning light came on and I dont know what to do. My bike has 300 miles. I just put on the TFI and AIS removal could that do it?
#2 ·
Do a search for engine code #37 , It's most likely your idle speed adjustment. Take off your seat and turn the silver thumb screw to adjust your idle too 900 RPM. This should cure the problem, You may need to ride the bike a few miles before it will clear, Your dealer will tell you that it is the code for the Linear Control Module, Adjust the idle . But do the search on this site first there should be a Bunch of posts on this topic because I think most of us have seen it at one time or another. Don't beleive everything the dealer says either The warrior is still a new model to most of the Mechanics.
#12 ·
I highly recommend to anyone who has'nt to purchase the shop manual to do so. They cost approx $50. Read, read, and re-read the section on fuel injection and the trouble shooting. If I understand correctly, a trouble code will show in the clock window. The code indicates what is generally wrong (rpm, crank sensor, etc). The codes are shown in the manual. You can also input a code to test a certain sensor or circuit. The manual says if you get code XX, input code YY and certain values will or should show up. Then you take this info to asertain what needs to be fixed. Once you fix the circuit, the code should self clear or you can manually clear it.One good thing is that if some critical sensor goes bad, the engine will not run. These would be the crank sensor, kickstand, or tip over. The book says that if other circuits mal-funtion, the ECU just inputs a safe general value. So the bike will run, but may not be running otimally. I will say in some ways I miss the old carb and mechanical timing that was soooo reliable!!! What I dont miss is hit and miss re-jetting multiple carbs!!
#16 ·
Hey Sang mines gold too and I haven't had a drink in a long while. I don't know what color it would be if I was drinking; might be the same color as "raalllppphh" sees. lol. and I agree with AZ; most of these mechnics are still learning their P's And Q's on this bike. I paid $60.00 for my manuel.
