When reassambling, is it recommended to lube stubs with whatever type of 'grease' ? Copper stuff, because of the heat ?
Or will this 'weld' it together ?
Could use a little Anti sieze on the studsWhen reassambling, is it recommended to lube stubs with whatever type of 'grease' ? Copper stuff, because of the heat ?
Funny you bring that up @Thommy_STC i searched online … forums .. YouTube etc… everyone has there take on that I’ve heard use of Anti-seize but also hear with the heat the motor produces it burn off in time … for the stud going into the head what you guys think ?When reassambling, is it recommended to lube stubs with whatever type of 'grease' ? Copper stuff, because of the heat ?
Being that I’m not the original owner as I go through this bike I discover flaws in repairs and installs as I go through I try my best to correct. And yes the flanges one the aftermarket exhaust to have a slight bend with the front being the worst wondering if I can bend back ??.@209SamoanWarrior ... My 2¢ follows:
Based on the enclosed photos you have or had an exhaust leak @ the front head pipe based on the discoloration of the stud and the c'bored hole.
A bent exhaust stud and or head pipe flange is 'A' typical of an aftermarket exhaust that's manufactured with a thinner 2-bolt exhaust flange such as V&H pipes because of the false tightening using the factory torque specs up front. This fact is well documented on the RSforum.
The OEM stud is technically known as a milled tapped end manifold stud and has a different Class Fit on the short threaded end that goes into the Head.
The YFSM calls for 11 ft-lb torque and no thread lock application. I suspect that the OEM stud end bottoms out in the threaded hole and sometimes picks up a small portion of the aluminum thread on the end of the stud during removal.
- OEM Exhaust Stud << Explanation
Here's an excellent detailed post by @rij1 aka Rudy:
- I would suggest using a high temperature anti seize compound for your new studs and fasteners and be sure not to over torque the front fasteners. I use a 1/4" drive for the front head pipe flange nuts and anti seize compound on both sides of the OEM exhaust gasket.
Here's an excellent post by @umpire3Being that I’m not the original owner as I go through this bike I discover flaws in repairs and installs as I go through I try my best to correct. And yes the flanges one the aftermarket exhaust to have a slight bend with the front being the worst wondering if I can bend back ??.
so my plan with the new oem studs is to air gun out the holes it’s only The clutch side whole that seems to not want to accept the new stud as easy as the other side but starts with the help with a Ratchet tho I did not follow through with install till I ran it by you guys . Didn’t want to make things worse ya know
