First oil change
770 views 7 replies 7 participants last post by  Centerline
I am doing my 600 mile break in oil change, following the owners manual instructions for draining the oil but cannot get the reservoir to drain. For those of you veterans
out there, is there a trick to get it to drain?
#4 ·
Before I do anything on my bike I always search for it here first. Saves lots of time. Glad you found the right bolt. Don't be to upset, there are alot of posts on this site about changing oil the hard way.
#6 ·
Did my 600 mile oil change last night using the instruction found here and I got the oil out just fine. Had to use a screwdriver to get the blinking oil filter off, but hey, I've done that on many cars before.
When filling with Mobil 1 V-Twin I followed the instructions, putting in 2.6 qts, running and then putting the rest of the oil in. Problem I ran into was after putting in the 4.3 qts called for in the owners manual. That didn't even get to the tip of the dip stick I put in 5 full qts and still just got to the tip of the dip stick. When I added another 1/2 qt the oil level went to over full so now I guess I get to drain and try again, being way careful on amount put in as it goes from not registering on the the dip stick to over full very quickly.
